Man of Honour
- 29 Mar 2003
- Stoke on Trent
Does Musk use full self drive in his tesla ?
I'll wager that like for like humans still kill and maim more people than self drive cars.
There seems to be a lot coming out about the CEO.The problem with this Titan situation is that the CEO only cared about "innovation" and turning the Titanic into a tourism spot as quick as possible without spending the $$$ to properly make it happen. In his own documentary you can see him say to customers on-location that if they want to back out they are welcome to do so and instead of offering a refund, he states that they will see to get them on another mission in another year - This trend correlates with what people who previously backed out have now said, that he would visit them and not give a refund but instead talk the world of what they could experience and try to persuade them to get back on the roster etc
In that same documentary one passenger on the ship's deck says "I know it looks like it's well built, but it is" as the camera shows the Titan in frame - If only he knew...
Bloody hell. Drunk or a vivid imagination?Netflix were probably hoping the rescue crew looked through the portal to find someone eating someone else. They get to the surface, as they undo the last bolt a vampire shoots out. Because at that depth. There's a 20.percent chance of "turning".
Bloody hell. Drunk or a vivid imagination?![]()
Why is this rubbish still in news, I dont give a dam what happened to them. people die everyday...
Yes, nothing brightens the day like a screaming fountain of **** and pukeOn a brighter note, babies are born every day also.
They may only have had a few seconds between a possible sensor alarm and the instantaneous implosion. Or it could have been minutes, but we'll never know.Spotted this on Reddit.
“Cameron says his associates and friends in the underwater world told him the evidence in the debris field showed Titan had dropped it’s weights to make an emergency ascent to the surface.
The crew knew the haul was in trouble and began an emergency ascent.”
If that was the case they would have known they were in grave danger and did they relay a message back to above they were coming back up.
The actual implosion is isntantaneous.I suspect when the hull is failing at that depth, it is only a matter of seconds really. Just like a ballon being popped. At least the folk didn’t suffer.
God help the families… No body to bury
If anything good can come out of this, then it’s to ensure it can never happen again. No more kamikaze subs and proper certification/regulation.
The question is, did they have any kind of advanced warning, from the sensors we know were on the hull, that something was wrong, before the implosion event.
If they were trying to make an emergency ascent, which is the theory from Cameron and others, then they knew something was wrong.
If as reported the implosion event happened a 1h 45 into the trip, they hadn't reached the bottom/target site, as that took ~2h 30, iirc.The actual operation of the vessel has not been made clear really. I read a few days ago that the vessel dropped it's weights at the bottom of the descent to become neutrally buoyant for the actual manoeuvring around the wreck. Im not sure if it then has to drop more weights for ascent.
So if this is true it could be the routine weight drop they are seeing?
"Dive into anything"? Bit insensitive, no?
