- 31 Jan 2022
- UK
Carbon fibre composite suffers brittle failure. That’s probably the main reason why it is not used for such application. Ie evident in this sub - it was ok for a few use then suddenly it goes pop without a warning.
Otherwise the composites has very high tensile as well as compressive capacity if cross weaved.
The fundamental flaw of the sub design I guess is a deviation from a spherical design to a tube design which means the stress build up in the materials will be highly concentrated around where the end bells connect to the tube and the likely failure point. The tube fiber hwould have been primarily weaved to deal with hoop stress but the longitudinal stress can be exceptionally high as well meaning the tube is prone to high end compression and if not dealt with the tube will just fail.
That’s probably where titanium composite excel ie it’s strength is not uni-directional and it is ductile so gives you plenty warning and ability to inspect and predict failure.
I would be very worried about the joint between the titanium and the carbon fibre. Different reactions to pressure would worry me. In fact, using carbon fibre would worry me full stop. It's not a widely used material in marine applications, there just isn't enough data.
And you are right about the way it was woven. It was woven in hoops with almost no longitudinal strength. I guess they thought it didn't need it. I wouldn't know. But I would certainly worry about that.
