My cabin setup, ie the batcave
you need more pictures of your kit?You need more sofas.
This looks fantastic! Have you thought about some acoustic panels to help bring down reflections a little? I think it would tighten up the sound a lot.
Thanks mate.
Yeah I've been thinking about it! Do you think behind the speakers would be best placed?
I already have carpet? LolCurtains to reduce reflections from the patio doors
Carpet for that hard floor
Your sofas will help also
I'll add another sofa for good measure
My port plug collection
- 120" Duronic 16:9 Screen,
- Sony VPL-VW320ES 4K PJ,
- Denon AVXR6400H 7.2.4,
- QAcoustics 3050 Front Standers, 3020 x 4 Side/Rear, 3090C Centre, 3070S Sub and QAcoustics QI65S x 4 Atmos,
- Panasonic DB-UB820 4k Player,
- Toshiba EP30 HD-DVD,
- XBoneX,
- Rega Planar 1 Turntable
Yeah, when I built it, I was on a tight budget... but yeah I will be going two subs as can power two through the amp, all wiring is already in ready for the day i pull the trigger. Problem is, life and cars is sucking all my money at the minute!Good system but that is massive open room is be looking at couple of 12" ported subs at least to two 15" subs
- XBoneX,
Yeah cheers man, yeah I do... we watched Blade 2 down there the other night.. just everything about it... however, I generally only go flicks now when watching iMax as tbh, I get a better experience at home now hahaha... so that's a downside and an upside... depends which way you look at it.This is class. You must smile every time you walk in here. I know I would.
But yeah, come together nicely just need to finish little things now and odds and sods...
Saving up for sub upgrade? Two of these should be about right
SVS PB-2000 PRO REVIEW & DEMO - It Shook The Movies Off My Shelf! I SPEC OF TECH
This is my full review and demo of the SVS PB-2000 Pro subwoofer. Make sure to hit the like button.Thanks again to Summit Hifi for supplying this review uni...youtube.com
Then upgrade to these
ELYSIAN 4
A genuine example of luxury audio, ELYSIAN offers indulgence in design, materials, aesthetics and performance. A thorough and no-compromise approach has led the Wharfedale engineers to create a benchmark in affordable, audiophile-grade luxury loudspeakers. Cutting-edge design and class-leading...www.wharfedale.co.uk
ELYSIAN C
ELYSIAN Centre brings a new dimension to the ELYSIAN series performance, tuning the application for mind-blowing home theatre settings. Each component part is engineered to the very highest standard. The drivers, the crossover, the cabinet – every aspect has been developed in harmony and without...www.wharfedale.co.uk
ELYSIAN 2
