- 7 Sep 2020
- Gods Country
ChainsawAnyone got any recommendations on the best way to cut sleepers? Correct tool for the job?
I used a chainsaw but it wasn't man enough for the job, burnt out in a shower of sparksAnyone got any recommendations on the best way to cut sleepers? Correct tool for the job?
They are the garden centre ones 200 x 100. I've been looking at the Dewalt cordless stuff, including the chainsaws...bit of a wuss about them though.
I cut one a while back using a handsaw and it took way too long. Possibly not the right handsaw though, or just a rubbish one...was brand new.
Recently got the DeWalt electric chainsaw and pleasantly surprisedThey are the garden centre ones 200 x 100. I've been looking at the Dewalt cordless stuff, including the chainsaws...bit of a wuss about them though.
Should be enough room behind to plumb the tap in. Long flexibitails fitted beforehand so you only need to secure the tap.2. How TF do you plumb a tap for a Belfast sink, lol? Surely you don't have to remove the worktop should it ever need replacing? :S
Bow saw? Too rough?They are the garden centre ones 200 x 100. I've been looking at the Dewalt cordless stuff, including the chainsaws...bit of a wuss about them though.
I think you're right... I had understood as much as remove sink but couldn't figure out how to remove. Dropping the legs makes sense but I'm tight to my fittings. After mulling it through overnight, luckily the unit to the left of my sink is the dishwasher so I'll have rear access.When I did mine I pre-attached the tap to the worktop before I installed it.
The way of dealing with a replacement tap from what I have seen is to unscrew the sink cabinet from the wall and adjoining units and drop it down using the legs and lifting the sink out after taking the waste off.
Figured I’d deal with it if I ever needed to at the time. I did also was cut a decent hole in the top of the unit so I could access the tap from below if needed but the cupboard is tiny so I doubt that is realistic.
Might be an option, hasn't got to be too perfect.Bow saw? Too rough?
Id probably make the back panel removable and also have some isolation valves in there.I think you're right... I had understood as much as remove sink but couldn't figure out how to remove. Dropping the legs makes sense but I'm tight to my fittings. After mulling it through overnight, luckily the unit to the left of my sink is the dishwasher so I'll have rear access.
Yep, you can click/tap on the username and there's a little clock/rewind icon to show you what the user name used to be.Edit: was @Classic Blue Theme formally known as dLockers? Have I missed something there?
^ did a tee to an appliance valve for the dishwasher that will live to the left of this unit. I ended up having to use the old trap as the McAlpine one was a fraction too low to meet the waste. I then had to join two 135 degree angles to make it all fit perfectly.
