Asus warranty repair - all data wiped.
Caporegime
8 Jan 2004
Rutland
Just got my laptop back from Asus to replace a dying fan.
They've wiped both the primary and secondary HDDs and left a test account on the system?
Is this normal practice? What an utter ball ache to restore my entire system for a fan change.
I would imagine it's fairly standard - they won't want to liable for any personal data that they inadvertently come across.
In most cases manufacturers don't necessarily guarantee you to get your exact product back - so usually don't guarantee your data back either.
That's a surprise with Asus, they have such a good reputation at the moment, both with the high quality of their merchandise and after sales service.
I may be being sarcastic here.
I knew when they farmed it out to a third party it was going to suck.
The whole thing seems sloppy:
- they could just boot from an external drive for testing
- they couldn't be bothered to just refresh windows back to new, instead just left the test account on
- wiping the secondary SSD seems ridiculous
- cosmetic damage from where they've pried the base off
I bet they've just slapped normal TIM on it too.
This just seems normal for Asus though.
theres probably small print somewhere
warning you data may be lost
but yeah they could just use a live usb
to test the repair of a fan
and as armageus said too
sometimes the fault could be hard drive or windows
so data would be lost then
or they may replace the whole thing with a newer model
if you get lucky
good news is sounds like
you may actually have backups?
even if restoring them will take a while
if you get lucky
I've got a full backup but it's just a pain in the arse to have to do that for a fan replacement.
Pretty much standard practice though it catches a lot of people out, they don't even guarantee you'll get the same device back - some people with Asus's 3rd parties have returned a perfectly good device for a small repair and got a ropey refurbishment back with more issues than the one they sent in.
Repair attempt number 2 has begun, Asus refused to replace, but have offered a warranty extension as a goodwill gesture. Lets see how this goes!
This is going off topic a bit, but I was looking at Le Cruset pans, that offer a "lifetime warranty" but having a read through the terms it says it does not cover wear and tear.
Well I'm not being funny but the thing is a solid bit of metal, what possibly else could go wrong?
Basically it's completely worthless.
