Looks really great but would be funny is there was a misprint![]()
I doubt it would be funny with the amount of work put in to it and so don't shoot the messenger! Aren't there a few capitals missing as in TAG McLaren? Depends on what the display displayed.
Nah, you're just not trying hard enough! ;POCUK have sent me 140mm fans LOL. Might be a bit big.
Ah, the joys of variable thickness material. You've got a few options:Actually you can see it wasn't my fault. Both ends? are fine. The acrylic is clearly p1553d.
My original DVD player showed the same Tag logo as this before going onto software version and disc information.![]()
I won't lose sleep over a capital L
Reminds me of my systems I have manufactured & put in these build logsRight. Held up today. Before I run the machine.... I bought 100 of these.
I ordered an A3 sheet of 3mm matt black acrylic too. Oh, and 100ft of black braid. The orange is already on its way.
The HDMI cable is not long enough. That was my fault, I really should have had a plan and measured it properly before ordering. Lesson learned...
I also got this.
Remember when people did that? aye, me too /old. Sadly I could not find a 24 pin, so I will need to cut off the 4 pins in black and put it in next to it. However, it gave me an idea. 4 orange wires in the black part, and black in the orange. Should look dope. I *think* I have some orange molex connectors at my flat. I broke this down after the case got broken in transit.
So there may be one in there. IDK.
Right, off to play CNC, wish me luck !
What you have looks excellent and unless you come across someone else who has owned this equipment before then nobody will ever know
If anyone ever asks if it's the same as the original. I will always back you upI'm no doing it again lol. That was really fiddly and frustrating ! plus it was a one shot deal. It would destroy the blue bit trying to remove it. I'm more than happy with it tbh.
This is going to be really good when it's doneRight so last update for today. Tired now lol.
I first designed the floor panel. This is what the PSU and mobo will mount to, as well as the fan hub and so on.
I also finished the power button.
I wasn't going to put that brace bar back but I had to. Because it holds this up.
That will all be getting painted satin black, but obviously not until everything has all been test fitted and so on. Otherwise I will be chasing my tail every time I scratch it.
oh well, more the merrier. I should also be able to play with the DVD drive tomorrow, as it should arrive then. What is concerning me a wee bit is the CNC lump that goes on it is machined out. The DVD drive I bought will be flat when closed, so I may need to machine a plate that it can stick to, and then stick to the front of the drive. Or, I will see how much clearance I get by removing the front of the drive (but obs not the tray front). That may get me over the line, but I am not adverse to more machining. The board tray will take about 2 hours, so that will be done when I come back. Need to leave on Thurs, have a lot to do at home.
