) and the laptop I use for productivity is a 10870H instead of something newer.If you're not going to watch? Why comment? And AGAIN with the "glue" + "skylake" + "atom" thing? You are a broken record.Not watching the video, but is it because that chip stock is pushing as near to the maximum data flow as Intel’s current ringbus design can handle with two memory channels?
Edit: Or could it because Intel don’t have the glue to bound Skylake to Atom and Atom mesh architecture has some pretty bad disadvantages?
Edit: Could it be because you have to pass Intel chips through more layers of abstraction for the OS to figure out what it’s is working with?
Is it because of all of those reasons?
Seen the vids, seem to be latency issues due to tasks jumping from e cores to p cores i think.
He needs to test with e cores disabled to see if it still happens
If you couldn't be bothered to watch the video I am a little surprised you think you have anything of note to contribute to this thread other than your general anti Intel diatribe and conjecture you've posted on many previous occasions. I did watch the videos and the TYC contributor was not sure himself as he is "not a CPU architect".You don’t say. That’s a topical comment to make, one that’s been pretty well disused many times. Think of a big + little core mis-mash as a work around to overcome other problems. You have accept some compromises with this format. Seems this YouTuber has come across compromises.
i am going to assume its an heat thing??
I’ve already seen these issues, ringbus and mesh across a decade.
Do you have anything worthwhile to add past watching a video?
Watch the video's, turning the E-Cores off makes no difference, they tried that, its because the input controller is on the motherboard with 12'th and 13'th gen.
Think about it, the thing that's controlling all of your inputs is not a part of the CPU, its a separate chip on the motherboard, so every time you action your mouse the signal is sent through the motherboard security before it reaches the CPU to be processed, with the 10900K or older, down to Sandy Bridge, and Rysen the IO input controller is on the CPU.
10900K or older,
Can i assume the motherboard chipset controls the Ring bus then? Never looked into it aside from overclocking it.
