The Gucci belt of the paint world.Decorating my daughter's bedroom
Costs as much to build the room as paint it!
Even the cost of valspar makes me wince
When the SSD / enclosure you've bought gets really hot in use and sits feeling just quite warm at idle, there's only one thing to do.
Heatsink it. Found this heatsink for just under six quid.
I've not got any thermal pads between the case and the heatsink so it's not going to be the most efficient but I'll see how it goes. This isn't used as a portable drive, it's just hanging out the back of the computer and it's not somewhere visible.
Yup, that's the one, he does a decent job of explaining why it's the price it is - You pay for the performance.Saw this video on this case
I don't know if he's downplaying the heat thing or whether the SSD he's using just generates less heat than the Samsung 990 Pro. Without the additional heatsink, even though it feels very hot, it's probably nowhere near hot enough to cause any issues but for the sake of just under £6, this was worth doing.
I can barely feel it's warm at idle now. I just copied 500Gb over very quickly and my IR thermometer gun showed about a 3°-4°C increase. That just makes me feel a lot more comfortable.
Don't forget that I'm running nearly three times the speed you are with the new enclosure. That'll make a big difference.I guess how hot it get is relative on how hard it is being worked, mine is running cold, transfer some stuff totaled 10G over and the temperature hardly changed, went from 26c to 30c.
Hence I said it's relative. FWIW, at idle, it is completely cool in mine.Don't forget that I'm running nearly three times the speed you are with the new enclosure. That'll make a big difference.
He thought I'd brought something home for him, then realised it was a terrifying machine and hid from it!I like the Doggo.
Sauvage and eggs for breakfast
We found the millionaireThe Gucci belt of the paint world.
I fully intend to call my next cat or dog "cat" or "dog". Always wanted toYou called one of your fish 'Fish'...?!
Cat = cat. Dog = dog.as in a cat called cat? or a dog called cat?
I fully intend to call my next cat or dog "cat" or "dog". Always wanted to![]()
I once had a fish called WandaYou called one of your fish 'Fish'...?!
