i've got dominator expo 6000mhz ram and with the latest 7b update i installed earlier i can run 6200mhz no issue and on a 1:1 ratio, tried buildzoids ram timings but ran into problems with bios freezing had to clear cmos a few times to get my pc to boot again, the sweet spot with the newer bios's look to be around 6200-6400mhz max, i would still look at 6000mhz kits and see how far you can overclock it and save some money.
not all cpu's will be able to hit 6400mhz but most will do 6000 easy and with some tweaking in the bios 6200mhz should be doable, any more than 6400mhz and the cpu will have to work at a 1:2 ratio and the increased latency wont yeald anymore performance regardless if you can run 7000mhz+ in games, benchmarks may be diffrent but haven't tried
