"cheap" fridge freezer brands - all of a muchness?
6 Oct 2004
Birmingham
This is embarrassing...
We've given the kitchen a bit of a refresh, including new flooring - the new floor is about 5mm thicker than the old one, and now the fridge-freezer doesn't fit!
It previously <just> fit under the sloping ceiling below the stairs, but now the gap is too narrow/low - here is my completely not to scale diagram:
It's >10 years old anyway and is looking a bit tatty, so we figured why not replace it (the other option being start taking chunks out of the freshly painted slope under the stairs and hope there's a bit of space which isn't guaranteed!), however have now run into the issue that any of the "decent" brands just don't fit :(
So far the only options I've been able to find are:
MONTPELLIER MLF1770W (or same model with water dispenser) -277L - 1770mm H x 540mm W (£339)​
HOOVER HV3CT175LFKW (or same model with water dispenser) - 252L - 1760mm H x 545mm W (£329)​
SHARP SJ-BB04DTXWF - 268L - 1700mm H x 540mm W - (£339)​
BEKO CSG3571W (or equivalent Indesit/Hotpoint as these are basically all the same other than the badge?) - 262L - 1740mm H x 540mm W (£329)
Candy CCT3L157FWK (or same model with water dispenser) - 252L - 1760mm H x 550mm W (£329)​
Liebherr CT2931 - 270L - 1571mm H x 550mm W (£544)​
Or silly expensive option:
Liebherr CNd5023 - 280L - 1655mm H x 597mm W (£829)​
On one hand, the Liebherr CT2931 seems like it might be a good idea if it's better quality and lasts longer. On the other hand, it still only has the same 2 year warranty as the others, so maybe I just grab the cheapest one and cross fingers!
Thoughts on any of the above?
Without having read individual reviews, the only thing you can base it off is general reputation for manufacturing for the home country of the company. Sharp is Japanese, and Liebherr is Swiss-German, so those for me are the countries with the best reputation for build quality. You can get some info on the origin of the other companies on this fridges page.
That's sort of what I was thinking, Montpellier is British (which I guess is either a plus or minus depending on your views of British manufacturing :p). However when I think of Sharp, I think of cheap Argos TVs, which is what's putting me off somewhat :p
The Liebherr CT2931 is the most tempting, but at the same time it would need to last a long time to be worth 60-70% more! If it had a longer warranty (e.g. 5 years) like the similar priced Bosch, Samsung etc., then it would be an easier decision, but for that price, 2 years seems a bit low!
I'd swerve candy hoover completely tbh. Check the specs for what's deemed acceptable/not faulty noise levels. The buzz from the compressor on my FF drives me nuts.
I did check, but I don't think that would work - it has recessed wheels at the back which don't look easily removable, and the feet at the front are at the lowest adjustment :(
Get the hacksaw out :p
Haha, I was tempted to take the angle grinder to it tbh :p
Decided to just bite the bullet and grab the Liebherr CU2831
Managed to get it down to £414 including recycling the old one, and looks like we can extend the warranty to 5 years for £80 or 10 years for £160 directly with the manufacturer if we decide it's worth it.
Good strategy IMO, but worth pointing out Sharp refrigerators are made in Turkey (Vestel) or their own facility in Indonesia.
Missed that
np - excuse to get a new shiny fridge anyway (oh the things that make us happy in middle age eh? :p)
To be fair, the old one didn't owe us anything, it was starting to look pretty tatty, and the door seals were going, so it was due a replacement almost certainly sooner rather than later anyway!
Edit: it was an Ariston brand one, which apparently ceased to exist in 2011, so that shows it's age!
For fridges.. I don't think in my entire life I've seen/had a fridge. Or freezer that's packed up.
I'd be more interested in the noise levels myself.
I don't even know what ours is. Came with house. Cheap/expensive.. Doesn't seem to make much difference. It's same technology and ita been around for ages.
I bought a beko about 3 years ago.
Was a bit noisy when I first turned it on but I think it must have gone into overdrive mode to get to temperature.
It settled down after about a day and I'd say it's very quiet... You can hear it a little bit occasionally but nothing intrusive, and that's in an open kitchen living room with tiled floors and it never bothers me.
