This is embarrassing...
We've given the kitchen a bit of a refresh, including new flooring - the new floor is about 5mm thicker than the old one, and now the fridge-freezer doesn't fit!
It previously <just> fit under the sloping ceiling below the stairs, but now the gap is too narrow/low - here is my completely not to scale diagram:
It's >10 years old anyway and is looking a bit tatty, so we figured why not replace it (the other option being start taking chunks out of the freshly painted slope under the stairs and hope there's a bit of space which isn't guaranteed!), however have now run into the issue that any of the "decent" brands just don't fit
So far the only options I've been able to find are:
Or silly expensive option:
Thoughts on any of the above?
MONTPELLIER MLF1770W (or same model with water dispenser) -277L - 1770mm H x 540mm W (£339)
HOOVER HV3CT175LFKW (or same model with water dispenser) - 252L - 1760mm H x 545mm W (£329)
SHARP SJ-BB04DTXWF - 268L - 1700mm H x 540mm W - (£339)
BEKO CSG3571W (or equivalent Indesit/Hotpoint as these are basically all the same other than the badge?) - 262L - 1740mm H x 540mm W (£329)Candy CCT3L157FWK (or same model with water dispenser) - 252L - 1760mm H x 550mm W (£329)
Liebherr CT2931 - 270L - 1571mm H x 550mm W (£544)
Liebherr CNd5023 - 280L - 1655mm H x 597mm W (£829)
On one hand, the Liebherr CT2931 seems like it might be a good idea if it's better quality and lasts longer. On the other hand, it still only has the same 2 year warranty as the others, so maybe I just grab the cheapest one and cross fingers!Thoughts on any of the above?
). However when I think of Sharp, I think of cheap Argos TVs, which is what's putting me off somewhat
