For launcher you can use playnite but per game profile is definitely handy.Yup the console on these is not amazing, my device is a sister device to the onexfly running all the same stuff, Asus Armoury crate looks amazing.
Leaked images reveal Lenovo’s Steam Deck competitor that may connect to AR glasses
It apparently has removable controllers.www.theverge.com
Colour me interested
Lenovo Legion Go to come with AR Glasses, launch timeline & specs revealed - Gizmochina
Lenovo is releasing a gaming handheld called the Legion Go. It’s a new product that combines the strengths of its competitors while introducing its own innovations Design and Performance The Legion Go is a gaming handheld with a practical design and powerful performance. It has well-positioned...www.gizmochina.com
microSD card slot on the top... However it has 2 usb c ports
It's good news, competition driving innovation and more choices for the consumer. What's not to like?Is this good news?
Or bad?
If you mean microSD card position them could be bad because it's borked on Ally possibly due to heat in that area. Other than that, competition is alway good.Is this good news?
Or bad?
'sideloading' new drivers
Reddit - Dive into anything
www.reddit.com
That driver deffo helps if you're using yuzu, you don't get any artifacts on a certain big game. Yep 900 deffo seems interesting.Seems interesting although no real firm confirmation if it improves performance or not (posts suggesting big gains without context and then others stating no real change).
Might have a play myself if I either remember or find the time (more often than not I pick it up, play on it and then forget about everything else I wanted to test / try).
I did see a few posts mentioning a 900p option which looks to be via a Reg edit. Might have to give that a look as that resolution can often be the "sweet spot" between 720p and 1080p in terms of clarity and performance.
High street retailer, that is Indian food.The Purple Store? Is that like Steam or Epic?
