- 11 Aug 2007
Ah, okay, thank you for clarifying.1st September.
Only people that are playing have a review code.
Obviously I hope I'm wrong, but I reckon it'll be a cluster **** with the AMD codes.
I reckon they'll be late, minimum few hours.
I agree, bizarre. Fallout 76 was an Xbox game too, so may be the same reason as that.Just seems strange considering it's an Xbox game as well.
I thought the partial controller support was aimed at steam decks?I agree, bizarre. Fallout 76 was an Xbox game too, so may be the same reason as that.
Found someone on steam saying about Fallout "It has full controller support. The 'partial' bit means you have to type in your name using a keyboard when you create your character or if you rename your equipment."
Could well be. Just quoting what I read, as I personally would never play Fallout with a controllerI thought the partial controller support was aimed at steam decks?
You'd think so.
I'll have to see to be fair I was playing CB2077 on RT Overdrive mode at Balances DLSS and it was slightly dropping below 60fps and it didn't judder so perhaps it is working. Quality and it was a total judderfest clearly when it hits 40fps it's useless.
I used to be perfectly happy playing games at 30fps I'm not sure what's changed, I don't remember years ago games at 30fps looked like a total juddery lag fest.
It's gamer merch so it will sell. Wonder if OCUK will stock? Lol
And then cyberpunk?You joking? they will probably re brand them into Doom ones complete with pentagrams
Want..
