- 25 Sep 2012
- Scotland
I took a closer look at the "review" of the T101 speaker that hornetstinger posted and it seems pretty amateur hour for someone with the proper measuring equipment.
So it seems that all that was tested was a single satellite speaker on it's own, the aforementioned T101 speaker. KEF themselves make it clear that this is a sub / satellite package. These speakers were designed to be used in conjunction with a sub woofer. You would never run these speakers on there own without a subwoofer so why would you test them that way.
The next issue with the review is the way in which the reviewer positioned the speaker to test it. They placed it on the included stand and placed it infront of a TV screen for some bizarre reason. KEF recommend's placing the speakers as close as possible to a wall. I don't think the reflective materials of a TV are a sensible material to take precise measurements that are representative of the environment most people would use the speakers.
It seems many people also question the reviewers methods. Some quotes from the thread:
Here is the reviewer refusing to review the product in the manner it would actually be used in:
Here are some more posters questioning the testing methodology:
This is the sort of calibre of person that posts on those forums:
I think it is safe to say this review (one of, if not the only bad review of the T Series) can safely be ignored as seriously flawed.
"I question the reviewers use of a TV as a nearby wall for testing, and refusal to properly mount them. I can't take any of these measurements seriously if he can't be bothered to mount them correctly."
"I've said it before, if they are going to use science in the name of the site then things shouldn't be done haphazardly just because it is fun to bash products or because it would be inconvenient to do them properly or a letdown to skip the test.
Let's mock the unscientific and then be unscientific ourselves."
"It seems like a speaker who's main purpose is being attached to a wall should be tested attached in the designated manner to a wall.
We can dance around all the different methods it can be used in but the real single reason for it existing is to be attached to a wall. If someone wants to argue that it has a stand and can be used in other settings then test it in both.
And since they (KEF) note under the "IMPORTANT" (section in the user manual) in bold that distortion will occur if you try to send bass frequencies to the speakers; were bass frequencies sent to it during the listening test? Are the operating manuals read before tests are done? It seems like there should be some level of familiarity with a product and its limitations before testing.
But, hey, why bother with looking at and possibly improving actual testing methods when we can make fun of anyone that buys it or likes it. Let's just wing the tests and proceed with the bashing."
"There is a bit of irony in badmouthing companies for not doing things right when the tests done here are questionable and yet the results are posted and then we move on to the next 'scientific' product test."
"Unless a speaker is in-wall, we assess its performance using stand-alone free-field measurements. This is how they would measure it as well. Erecting a wall in an anechoic chamber is non sequitur. This is no different than any other speaker. We can't pretend to measure it the way you would use it in your room. We measure it in free field and then make predictions about its performance in the room."
"They're being tested with a protocol that was never intended for them."
"Using the standard "predicted in-room response" calculations that assume a wall some distance behind just aren't going to produce accurate results."
"I'm not sure putting it in front of a flatscreen TV is acoustically equivalent to wall mounting. Unless your TV is already wall mounted?"
Well that explains why it's so terrible, they had a woman design it
Seriously though, i've met as many female audiophiles as I have unicorns, let alone a female speaker designer
