Get a 5800X3D in there and your FPS and GPU usage will increase by quite a bit. Will likely need a BIOS update too but that may also help with your memory stability issue and have a nice, capable machine until next gen AM5 comes round.Just checked out the game on my system, same location as you were, higher resolution (3440x1440p)
Same settings as you posted above, no upscaling/FSR2 etc
Ancient CPU (Ryzen 2700X 32GB DDR4 @ 3000, 3200 isn't stable on my X470 motherboard)
AMD 7900XT
Got 50fps in the exact same spot, even running at lower resolution it doesn't change (tried 2560x1440p and 1920x1080p) so I am heavily CPU/Bandwidth limited, GPU use is ~50%.
For what it's worth if I had a newer CPU like the 7800X3D and DDR5 I'd be pushing over 100fps.
