**THE NVIDIA DRIVERS THREAD**
Yeah I'm not experiencing issues either but apparently latency is slightly higher than normal but I'm yet to see any real world result of it.
I guess i should download it and try it. Does this directly affect latency in games at all or just general workloads on desktop?
seems 537.17 is out
Release Highlights​
Although GeForce Game Ready Drivers and NVIDIA Studio Drivers can be installed on supported notebook GPUs, the original equipment manufacturer (OEM) provides certified drivers for your specific notebook on their website. NVIDIA recommends that you check with your notebook OEM for recommended software updates for your notebook.
Game Ready for Starfield
This new Game Ready Driver provides the best gaming experience for the latest new games including Starfield and the ICARUS: New Frontiers expansion.
Fixed Gaming Bugs
  • [Battlefield 2042] Game stability can decrease when applying GeForce Experience Freestyle filters [4170804]
  • [Ratchet & Clank: Rift Apart] Performance fluctuations due to issues between DirectStorage and NVIDIA Reflex [4212649]
Fixed General Bugs
  • [Vegas Pro FX] Preview not working on some notebook configurations [3752618]
seems 537.17 is out
Release Highlights​
Fixed Gaming Bugs
Fixed General Bugs
That's actually 537.13 which I already linked a few posts up ;)
I've taken my ''like" back! :p
Vulkan Beta Driver Release Notes
The latest Vulkan 1.3 specification can be found here: https://www.khronos.org/registry/vulkan/
NVIDIA provides full Vulkan 1.3 support and functionality on NVIDIA GeForce and Quadro graphics card with one of the following Ada Lovelace, Ampere, Turing, Volta, Pascal and Maxwell (first and second generation) based GPUs:
Windows 537.35
Download for Windows 10/11
Studio Drivers > Vukan Drivers - > Game Ready :D
NVIDIA GeForce Game Ready 537.34 WHQL
Game Ready for Mortal Kombat 1
This new Game Ready Driver provides the best gaming experience for the latest new games supporting DLSS 2 technology including Mortal Kombat 1 and Lies of P.
Fixed Gaming Bugs
[Starfield] Profile updated for Microsoft Store/Xbox Game Pass version [4266797]
[Counter-Strike: Global Offensive] black screen when using the GeForce Experience In-Game Overlay [4257572]
Starfield Performance Improvements
Today, NVIDIA is releasing a Resizable BAR profile for Starfield which increases performance on GeForce RTX 40 Series and GeForce RTX 30 Series desktop and laptop GPUs. In our testing scenario, GeForce RTX 40 Series desktop GPUs see on average a 5% increase in performance. The Starfield Resizable BAR update will be pushed via an Over-The-Air (OTA) update from NVIDIA and will be automatically applied for gamers running the latest Game Ready Driver (537.34) or the previous release (537.17).
GeForce Game Ready Driver | 537.34 | Windows 10 64-bit, Windows 11 | NVIDIA
Release Notes: NVIDIA Release Notes Win10
Fixed Gaming Bugs
Open Issues
  • [Halo Infinite] Significant performance drop is observed on Maxwell-based GPUs. [4052711]
  • [DaVinci Resolve] This driver implements a fix for creative application stability issues seen during heavy memory usage. We’ve observed some situations where this fix has resulted in performance degradation when running DaVinci Resolve. This will be addressed in an upcoming driver release. [4172676]
Additional Open Issues from GeForce Forums
Notes: This is not new. Manuel from Nvidia has been tracking any additional driver issues in their forum post separate from release notes. This is the first time I am including them here and will do so moving forward.
  • Small checkerboard like pattern may randomly appear in Chromium based applications [3992875]
  • Some monitors may display random black screen flicker when in Display Stream Compression mode when using R530 drivers [4034096]
  • [GeForce RTX 4060] GPU monitoring utilities reporting incorrect idle power usage [4186490]
  • Event Viewer logs nvlddmkm error at the end of the OCCT video ram test when memory is full [4049182]
  • [GeForce GTX 10/RTX 20 series] PC may randomly freeze/bugcheck when Windows Hardware-Accelerated GPU Scheduling and NVIDIA SLI are both enabled [4009884]
  • Horizontal band may appear when cloning a G-SYNC display to HDMI monitor [4103923]
  • A new NVIDIA icon is created in the system tray each time a a user switch takes place in Windows [4251314]
  • [Alienware X17 R2 w/ GeForce RTX 3080 Ti] Display goes blank when DirectX game is launched while notebook is in dedicated GPU mode [4146369]
  • [RTX 4060 Ti] Display may randomly flicker with a black bar on the top of the screen when using desktop apps [4239893]
I get this with a 4080
Have you ran this on your 4080 as they did need a UEFI update to rule that out ? It will tell you if it needs the update or not too and works on AIBS and FE cards.
NVIDIA GPU UEFI Firmware Update Tool​
Updated 11/18/2022 10:40 AM
To ensure compatibility with certain UEFI SBIOSes, an update to the NVIDIA GPU firmware may be required. Without the update, graphics cards in certain motherboards that are in UEFI mode could experience blank screens on boot until the OS loads. This update should only be applied if blank screens are occurring on boot.
Click here to download the NVIDIA GPU UEFI Firmware Update Tool v1.2.
The NVIDIA GPU Firmware Update Tool will detect whether the firmware update is needed, and if needed, will give the user the option to update it.
If you are currently experiencing a blank screen, please try one of the following workarounds in order to run the tool:
  • Ensure you are using the latest SBIOS from your motherboard vendor
  • Change boot mode from UEFI to Legacy/CSM
  • Boot using an alternate graphics source (secondary card or integrated graphics)
  • After powering on your system, wait for your operating system to load with the graphics driver installed
Once you have the tool downloaded, please run the tool and follow the on-screen instructions. Ensure all apps are closed before running the tool and make sure no OS updates are pending in the background. This tool can be used with Founders Edition as well as partner cards.
Applicable Products
GeForce RTX 4090, GeForce RTX 4080
Also check if your card maker has a VBIOS update for it too that may fix some known issues.
Why has DPC latency been removed from open issues? The fix was only for 30 series, 40 series still has DPC latency.
As for Starfield:
Driver 537.13
Average framerate : 107.9 FPS
Minimum framerate : 103.8 FPS
Maximum framerate : 111.4 FPS
1% low framerate : 80.1 FPS
0.1% low framerate : 67.6 FPS
Driver 537.34
Average framerate : 109.8 FPS
Minimum framerate : 106.4 FPS
Maximum framerate : 113.6 FPS
1% low framerate : 86.6 FPS
0.1% low framerate : 74.1 FPS
  • Like
Reactions: TNA
As for Starfield:
Driver 537.13
Driver 537.34
Was this for the Steam or the Game Pass version ?
It's got kinda annoying at this point, I think the Studio drivers have better control over DPC as with game ready, I do notice pops in some audio playback more often than with Studio. I'm on Game Ready as the Studio driver hasn't updated to the latest version yet.
Annoying!
