- 4 Aug 2007
- Wilds of suffolk
At best it was very badly worded. For example the sentence:
Is just nonsence. Its not the 'inefficiencies' that cause the heat.
The 'inefficiencies' are related to the amount energy turned to heat that hasn't performed some useful 'work' beforehand ( of course useful work may indeed be the intentional generation of heat for example for a cars cabin climate system)
Heat is the inevitable outcome of expending the energy stored in fossil fuel or a battery.
Sorry but in this regard, efficiency, hes right and your wrong.
Pumped storage gives us another example, its about 50% efficient.
You can take 1kwh of energy, use that to pump water up hill. Then release it back down again and have 500wh of energy available.
The losses, the 50% in this case is lost to generally heat, motors etc getting hot.
So you have stored energy for a period of time and then released that back later.
If you could pump it up hill, store it and then relase the water back down hill and achieve 100% energy back, ie zero losses your efficiency would be 100%.
Remember your converting energy here into another form and the releasing it back.
100% of the energy has not be turned into heat. 50% has.
Its a somewhat odd thing to be discussing anyway. reducing energy usage is just as vital as generating it more cleanly and sustainably which is what he was replying to.
