OK; fair play to Octopus to simply stand by the quote and subtract the new full amount.Mine was £6.1, it’s now £3.6k which is cheaper than getting an unvented cylinder and gas system boiler installed by some margin.
I think i would slightly swap them round to:Not a good luck if they don't pass on the savings 1:1 but we can't be sure if they were getting back end tax incentives that have been impacted.
I initially really wanted a heat pump on my next move but until gas cost changes Ive mentally de-prioritised it. If I get a pad with an old or knackered boiler then probably will bump it up the list but as of now mind is saying
insulation improvements> battery system > solar > heat pump
insulation improvements > solar > battery system > heat pump
Depending on your lifestyle, I think the ROI is higher with solar than with battery.insulation improvements > solar + battery system > heat pump
Add the word “efficient” or “modern” before functioning and I’d agree with you.It makes no sense for anyone with a functioning boiler of gas or oil to move to a heat pump
I dont think that equation is going to change for a fair few years
I was slayed for saying that earlier in this thread.I think i would slightly swap them round to:
Or maybe:
Glad more people are realising the fact that you can't just buy a heat pump and all will be fine and that we should all force the whole country to move to it.
The grant does little to help many improve there insulation and get solar panel sorted
They decrease your energy bill and a heat pump uses electricityI’m not sure I fully subscribe to the above.
All solar and batteries do is lower your electricity cost. They don’t change how much energy a heat pump actually consumed.
If you have solar and battery storage, the chances are you are not exporting much in the winter but you can obviously use your battery storage to lower the average cost of the electricity you use. It’s not impossible to power your heat pump entirely off battery which you charge up at 7.5p/kWh. You don’t actually need that much to cover the bulk of your heating demand for all but the coldest days. Any spare capacity in an existing solar/battery system will contribute to lowering the average cost of the energy you consume.
Ahh how come?Solar is not going to make virtually any difference to heat pump running costs we already had this conversation
It’s the seasonality. During winter, I produce one third of the solar energy I do during summer. The solar production during winter only covers my base electricity load approx. one day a week. On the other hand, during summer, there’s plenty of surplus to export. My heat pump usage pattern will be the complete opposite- high in winter, when I’m producing little and low in summer.Ahh how come?
Doesn't heat pumps run on electric and don't you generate electricity using solar panels?
What am I missing?
OK cool thanks. Was it cheaper to run your heat pump vs a gas boiler for your usage during winter?It’s the seasonality. During winter, I produce one third of the solar energy I do during summer. The solar production during winter only covers my base electricity load approx. one day a week. On the other hand, during summer, there’s plenty of surplus to export. My heat pump usage pattern will be the complete opposite- high in winter, when I’m producing little and low in summer.
Check the graphs here - https://blog.spiritenergy.co.uk/contractor/heat-pumps-solar-panels
The first shows normal energy usage whilst the second adds a (relatively low power) heat pump on top.
I’m going to have to defer that for a year! Got it installed in May so not really given it a fair test. I also installed underfloor heating and underfloor insulation at the same time so not an entirely fair comparison anyway.OK cool thanks. Was it cheaper to run your heat pump vs a gas boiler for your usage during winter?
I can’t imagine they’ll be offering a £7.5k grant forever. That’s a pretty impressive offer compared to the cost of a new boiler. Do you expect to need to do much fixing up after? Are they just switching things where they are rather than replacing pipes all over the place (which will require repainting etc)?Octopus have come back with £900 for everything including a hot water tank.
So with previous calculations that would take 7 years to pay off, then £122 a year better of Vs gas. What are the chances it will still be £900 when my boiler needs replacing.
For ASHP to work or worth changing in my house it needs to be COP 4, this is to do with gas prices and electricity prices. ASHP will use more electricity but my gas bill will reduce (I will cook as we need the Wok Hei), to compensate the increased electricity use I have ripple wind farm and also the solar farm which hopefully give me money back just as I would use electricity at cheaper rate.
If COP drops to 3 and below that would really mess up my calculations and of course if gas prices drop to 35% of current price then it would be a disaster too. I won't cry if my system shows a COP 2.5 but it just meant I wasted the governments £7500 etc.
