I wouldnt even have 4 intake as i plan to get the EK distro plate, which goes in the 3rd rad/upright GPU spot. It looks like you can put fans behind it, but unless you can use standoffs then presumably the air is just being pushed into the back of the distro plate. Annoyingly this spot is the best location of all entries for fresh air to enter as its right next to a window thats open >90% of the year. I also REALLY wanted to do the vertical GPU too, but it'll have to go vertical instead.Yes, it's hard to believe that they bring out a brilliant cae that supports 420mm radiators and then completely ignores bringing out a reverse blade uni fan in 140mm. The uni fan sl infinity is a great looking fan that just adds that extra touch to the finished look, without a reverse blade option then you have to have exhaust to and bottom with the side and rear intake but this isn't ideal as you have six fans as exhaust and four intake which is the opposite of what you want.
Thats interesting, ive never really paid much attention to fan configuration and typically just gone with an equal amount blowing in as out. However i have read bits and this is a negative pressure setup, right? So air gets forced into the case at fanless vent locations, and presumably combined with that fresh air to the fans blowing out gives better results than when you're immediately warming up fresh air and feeding it to another radiator etc?If you are doing fully watercooled build you are better off doing them all exhaust - tested all configs in original evo with 3x360. 9x exhaust was the best.
Now I have 3x420 all exhaust in evo xl and barely doing more than 6 degree delta below 1000rpm(4090+13900k)
I edited out pretty much the same sentiment from my post. One of the reasons i waited was because i fancied going with 420 rads, and having that extra cooling capacity if it was ever needed. If im now contemplating 360 rads all because i cant get the perfect 140s, purely for aesthetics, then i feel like i might as well have got the regular Evo. Saving £50 there, and another £40 on the fans. However apparently the EK distro plate has issue with a top 360 rad for reasons i dont think anyone understands. It just seems like a really petty reason to change the plan, which has its own flaws, because i dont want to see the fan frame - something ive genuinely never cared about until RGB fans came along.Yes, I'm gutted myself as it restricts options, if you really want to use reverse blade fans then you're stuck with the 120mm fans and 360mm radiators, and then there's no need for the Evo XL, you could just stick with the regular Evo.
I think Lian Li missed a trick here.
When you see Thermaltake solved the problem by creating a 2nd fan blade, and including it as a USP, it shows how its hardly a case of Lian Li needing to create a new product, its purely a new blade - one slightly bigger than the 120 reversed they've already managed to figure out and start selling. I can only assume they dont see a big enough market for it, yet they create a (2nd) bigger case ideal for 140mm fans.
I guess if all exhaust works well, then i'll go with that. I think as long as it wasnt meaningfully worse performing then i'd probably still lean towards aesthetics, so if its equal or better - great.
there might be different "revisions" in different colours as the design was quite fluid up until the very end.
I cant understand which axis would be compromised.
