*** Big Fat Weight Loss Thread ***
It seems a reasonable starting point, but I'd suggest keeping tabs on your weight and tweak it from there when you see how it's going.
FWIW, I was in a similar boat several years ago and decided I really needed to do something about my weight and general health. I managed to lose about 25kg through eating less and moving more, which I've kept off since. I could make a few notes of my experience and what worked/works for me it would help anyone.
I’d love to hear them
OK, this turned into more typing than I intended - hope it doesn't get too many TLDR comments :)
I think one of the biggest problems with putting weight on is that it happens so slowly that you get used to being big, and it's easy to convince yourself that it's not so bad that you actually have to so something about it. It's also easy to convince yourself that your weight isn't affecting your health or quality of life and longevity. Or that your family and friends aren't just being polite...
In my late 40s I'd topped 100kg and was very unfit and suffering with acid reflux and backache. It was the blood pressure going in the wrong direction that finally gave me the kick I needed.
Everyone is different, and what worked for me obviously won't work for everyone, but these are the main things I'd have suggested to myself 10 years ago:
1. Learn about calories in foods and drinks. Get to understand how many calories are in what foods/drinks by calorie counting until you get a feel for it - e.g. how many calories in a pint of beer, this lump of cheese, this massive bowl of cereal?
2. Learn about how your body expends calories just existing (BMR) and with exercise. Discover how depressingly few calories a swim or walk burns and realise that a calorie deficit is going to be mostly about eating less.
3. Find some exercise that you enjoy doing and can make a hobby / habit. Anything that gets your heart rate up will tend to burn more calories and provide some endorphins as a reward. It might not burn as many calories as you'd like, but you'll feel better and it's also hard to eat while exercising. Ease yourself into anything strenuous (and speak to your GP if appropriate) - you don't want to overdo it or injure yourself.
4. Work out a calorie intake based on your activity level and target weight loss. E.g. a 500 calorie deficit per day should give nearly 0.5kg/week. Treat it as a marathon, and not a sprint - don't start off with a crazy low calorie target and then give up when you find it's too hard. You're trying to find a system that works for the long term, so change the target as you see how things go. If it takes 6 months longer to reach a weight target then does it really matter as long as you get there?
5. Keep eating sensibly / healthily and what you enjoy - it's got to be sustainable.
6. Weigh yourself at the same time each day (or few days), but don't get hung-up on any individual reading as your weight can vary a surprising amount. Use a rolling average over a few days to see how it's going.
7. If you're going to have 'days off' or backing off because of a virus, don't let yourself go mad and undo the good work for the past week.
8. Don't con yourself into thinking "I've done this exercise, so can eat what I want for the rest of the day" - sadly that's not true for normal levels of activity. Similarly, don't think you need to pre-load or eat lots after moderate exercise - your body has a substantial glycogen energy store and you'll know if you run out (bonking in cycling parlance) as it feels unpleasantly different from hunger.
9. Try to work out your weakensses (e.g. nibbling in the evening as you get tired and willpower fades) and find distractions or other ways to moderate them. E.g. exercise in the evenings instead of sitting watching TV, have less junk food in the cupboards. Maybe avoid reading this thread while you're hungry in case someone posts about eating pizzas.
10. Learn to distingush the 'not full' feeling from the 'proper hungry' feeling. Try to associate the feeling of not being full with "it means it's working"; you won't really starve or feel weak if losing weight at a sensible rate.
11. Do it with others if you can for encouragement and motivation.
It took me a couple of years to lose the weight. It's mostly a mental thing, and it got easier once I'd been at it for a couple of months - partly because you get used to it, but also because you run out of excuses that it's not achievable.
For exercise, I got back into swimming, and was challenging myself to swim faster / further. I got myself a Garmin smart watch which got me interested in metrics and seeing the effects of training. (As a bit of an aside, seeing the effects of illness and alcohol on heart rate / heart rate variability is interesting, and I drink less now). When the pools closed due to covid, as an alternative I started doing more on a second hand exercise bike, which led to buying a proper smart indoor trainer bike and riding / racing on Zwift about 6 days/week. I seem to have turned into an exercise junkie that can make people's eyes glaze over with talk of VO2max, FTP and power curves. Apart from enjoying it, I'm feeling happier and fitter, with no backache and untroubled by acid reflux. I still tend to over-eat and on holiday can put on a kg or two, but knowing what I need to do, and probably more importantly knowing that I can do it, makes it far easier to cut back for a week or two.
I'm sure I've missed a few things, but that's basically what has worked for me and hope it's of some interest. Good luck!
I think the most important things are:
1. Don't beat yourself up when you fail.
2. Remember this is the rest of your life. You're looking to build a healthy lifestyle, that maintains a decent weight and decent fitness, etc. not hit a target and forget about it.
3. Any progress you make is still progress.
Today, I'm not so happy, I've put on about 4kg since February, it's all been a bit difficult over the last few months and I've drunk too much, eaten too much, and exercised too little. But I have to remind myself I'm still over 4 kilos lighter than I was almost a year ago when I decided I really needed to sort this **** out. And I do feel better for it.
Thank you for all that. Maybe these should be stickied.
I think these are the ones I really struggle with. I love to snack in the evening. Normally I don't eat very much, but sometimes I go a bit wild and eat some toast and a few biscuits and then other stuff...
Well done on your own weight loss. Where are you now?
No problem, and pleased if it helps you or anyone else.
Evenings are my main weakness too, particularly chocolate raisins. We're about to revamp the kitchen, so that should help keep me distracted in the evenings for a while.
And thanks - I aim to keep under 80kg, but will be a bit over that at the moment as I'm recently back from a holiday and now just getting over a bit of a cold (so little exercise and not thinking about calories while I get rid of the virus). When I'm properly back in the (bike) saddle I can easily burn over 1000 calories in a session, so a ride plus a few km walk each day makes it a lot easier to create a defecit. They say that you can't out-exercise a bad diet, but I could give it a good go from a calories point of view! I've toyed with dropping to 75kg to see how I feel (and improve my W/kg so I go faster up Zwift hills).
Keep us posted with how you're getting on.
2 weeks in. Pulled something in my chest doing a burpee last night so did squats and cardio. More cardio tomorrow and ive cut my diet down completely...
Somehow managed to put weight on...ya wha? Im assuming its due to muscle as im doing a lot of weights etc. My PT didnt think anything of it.
An example of my diet :
Tomorrow
3 boiled eggs to be eaten throughout the day
Chicken salad at lunch (lettuce, chicken (nandos marinade, cucumber, onion, jalepeno)
Maybe some cucumber sticks or a protein yoghurt
Tea is usually a chicken wrap but sometimes omlette with onion and pepper.
Tea is straight after a 1 hr HIT style workout.
My typical day is like this:
2 eggs, egg whites, scrambled and on toast.
Thins with ham, lettuce, tomato, and an apple.
Dinner is something like chicken and rice with vegetables, though not your bodybuilder style thing. More like Japanese or Chinese homemade style (not that I'm either) followed by a small ice cream.
Here's where I get in trouble: random snacks. When I get home, probably a couple of crackers. Last night, at about 11 I couldn't help myself and I had a toasted thin and then some biscoff on a spoon, as well as probably some other random small items. Finished the day around 2,300 cals having done a swim, though, so hopefully it's not too bad.
Weighed in this morning at 93.7 kg.
Finally dipped under 80kg this morning for first time in many years - 79.7kg.
I've been keeping to a calorie restriction that's about 10% below TDEE for a few months and scales have slowly been dipping. I weight at same time every day of course but there is always a range of about 1.2-1.5kg day on day (unless it's been a Papa Johns day, weight goes up loads due to the salt and water intake for a day or two)
Don't follow a set diet outside of certain key principles, just generally eat as I feel, hitting a minimum fat/protein goal for the day and free forming the rest. I do snack and eat 'junk' if I want, just keep in the calorie range and I do have occasional take out days here and there.
Whilst I fully expect to be back up over 80kg tomorrow purely due to fluctuations, seeing sub 80kg is quite a mood booster.
I ate too little yesterday in the day and felt terrible before dinner. Really hard not to overcompensate with snacks and junk. Reiterated the importance of proper meals to avoid snacking to me.
I’m at a different conference every day for the next three days. This will result in a terrible diet! Managed to only have one mini pastry with coffee this morning but willpower crumbled with mini Black Forest gateaux. Thankfully they were tiny! So much coffee as well :cry:
Well done!
Got home from work - 45min cycle, ro change and do gym...
Warmers etc , deadlifts on agenda 4x5reps 122.5kg
Then dumbell exercises and conditioning
2fish cakes with brocoli
Usually I don't lose weight after the gym but hope to get under 230lbs finally... been stuck on 231 for few days
Oh dear, noticed our local Tesco has their Finest Sausage rolls with bacon and cheese again. Definitely didn't demolish a pack last night.
In my defence, got into it with the missus yesterday and was miserable af - my excuse and sticking to it :D
i wasn't as lucky as you guys ...treated mysef to a good coffee and grabbed a fresh and warm cinnamon danish to go with it... walking back to work took one bite of it, and before i've noticed, the middle, best bit of the pastry ended up on the floor :(
not a happy bunny ....
but maybe it was a sign...
Im not struggling with food at all. Dont really have a sweet tooth, dont drink tea or coffee so no extra milk etc. 3 egg whites today and a chicken salad wrap is all ive had all day, prob another salad for tea and that'll be it.
