As I said, I can access by browser with the IP but not on the app.Why not just connect directly to the UCK by its IP address?
Network is working fine but I do like using the app to quickly check how things are. I'm the sort of person that when something's not working then I need to find out why and fix itThe app isn’t the full user interface. For quite a lot of things you still need to go to unifi.ui.com or direct local access. There are also differences between the iOS app and the Android app so I wouldn’t get too caught up in why this or that doesn’t work, so long as your overall network does work.
, especially as it was working before the change. My network is not big or complicated at all and it's only a Gen 1 CK which I know can have problems and is not updated anymore, can't justify buying a UDM though!Network is working fine but I do like using the app to quickly check how things are. I'm the sort of person that when something's not working then I need to find out why and fix it, especially as it was working before the change. My network is not big or complicated at all and it's only a Gen 1 CK which I know can have problems and is not updated anymore, can't justify buying a UDM though!
I did that but was still the same.Have you tried deleting the app and all associated files and re-installing it? It feels like an app issue rather than UCK to me.
For UniFi they only really have three options for a network router, those are:Afternoon all; I have Vodafone broadband with their router going into a Cloud Key Gen2 then off to 3 Ubiquiti wireless access points in the house and over in the garage.
I’ll be upgrading to full fibre from Gigaclear early next year and I want to use a Ubiquiti router so that everything is within the same ecosystem.
I don’t really understand network stuff so I get a bit confused about what I would need from their range.
Any advice or suggestions of what from the Ubiquiti range would be suitable to use a full fibre router?
Thanks!
Thanks!
For a synchronous 1 Gbit/s connection if you are wanting the security features turned on (Intrusion detection and Packet inspection) you are likely going to want to go with the the Dream Machine Pro since it can go up to 3.5 Gbit/s with those turned on whereas the Dream Machine standard can only do 850 M/bits.
- Dream Machine (White cylinder)
- Dream Machine Pro (Silver rack mount unit)
- Dream Machine Pro Special Edition (Same as above but with PoE ports and 128GB solid state storage)
A nice benefit if the UDM series is that you will no longer need your Cloud Key since the UDM also acts as a UniFi Controller and (If you have the UniFi Protect series cameras) a NVR as well.
If you do go with a UDM you will want to make sure whatever modem/router combo unit Voda send out can go into "Modem only" mode so it can pass through your public IP to the UDM or you will be stuck with "Double NAT'ing" which causes no end of issues.
While I do get the attraction of having everything in the same ecosystem the UniFi router options are very expensive, overburdened with ‘features’ I can pretty much guarantee you don’t want and very, very, average as actual firewall/routers. I would strongly suggest saving your money and just swapping in whatever router Gigaclear supply.
So, if it were me and I "had" to buy one I would go with the UDM Pro. Purely because if you have 1 Gbit/s available to you now it would be better to spend the £80-100 more to get something that will at least be "futureproof" for the next 5-7 years (I don't see 3.5 Gbit/s internet being available in 10 years let alone 5) rather than spend slightly less on the UDM and end up with something that is already potentially a bottle neck for your network.Thanks for the detailed response; those were the options I came up with too. I was hoping to learn there was an option of a decent modem/router that wasn’t also an access point but also not as expensive / complicated as the Dream Machine Pro.
Would the Dream Machine be OK if I went with the 600mbps fibre, or is that more to do with bandwidth across the network so would still struggle? I don’t really need the access point of the DM either.
I'll be honest I haven't used one in person to confirm however 3.5 Gbit/s seems a bit high I would say it would be above a gig since whilst it does have IDS and IPS it's not DPI-SSL (As far as I'm aware) since it doesn't require clients to have a trusted certificate for it.I wouldn't trust that 3.5 Gbit/s given how Ubiquiti usually over market their products, add upload to download and exclude features like IPS and QoS in those figures.
The throughput is even more impacted for people on PPPoE due to its extra overhead.
I normally purchase FS network cables, are the UniFi options decent? Now UK store back up and running mulling a 20 x purchase.
The biggest faff was configuring the many IOT devices to use the new SSID.Will have a look at this today, I don’t currently have a guest network as I didn’t want SSID sprawl. Meant when families kids came over, tough lol
You won't be able to use a speed limit on a guest network by the way, it applies to the whole SSID.
