Ummm... https://www.google.com/amp/s/www.th.../amp/The-reliable-used-cars-revealed-Car.htmlThe rise of people buying cheap Kia's, etc. seems to come hand in hand with issues like this in the last 3-4 years.
Kia's aren't particularly cheap these days!
But at least they're reliable ehNothing is particularly cheap these days.
.lol JLR appear to fill 3 of the 4 spots for least reliable .......good job I don't have one of those then hey!But at least they're reliable eh.
Depressing isn't it! Still, they're stimulating the local economylol JLR appear to fill 3 of the 4 spots for least reliable .......good job I don't have one of those they hey!![]()
. I'm not saying Kia is unreliable but a lot of the cheaper end of the range vehicles are increasingly made to a cost and that is having consequences.
Small and value cars were rated the most dependable for used buyers, scoring an average of 85.9 per cent overall in the survey.
By contrast, luxury SUVs proved to be the most troublesome vehicle classes, according to their owners, scoring an average 69.5 per cent overall
Seems to be the complete opposite at least based on the 25k people they asked.
So, update on the car, the shuddering I was feeling was actually misfiring. 3/4 spark plugs are done, being a consumable part they are not covered under warranty so I would be on the hook for £150 diagnostic charge and the work, lovely.
Car is due it's 4 year service in a month, where the plugs would be replaced anyway, so just having that service done a bit early, they can squeeze me in on Monday or Tuesday and they are not charging me the £150 extra.
I am a bit concerned that 13k miles is very low mileage for spark plugs to go and wanted to know if there was potentially something wrong that would maybe cause them to break again, but the service manager just kept repeating over and over that they needed to be replaced after 4 years and this is normal, so yeah, not great customer service, but I will have my car back sooner than if it had been some massive warranty repair/gearbox replacement.
100% but even the base models of a lot of brands are coming with decent amounts of tech these days so I think that gap between high end and bottom end when it comes to complexity is no where near the gap it used to be.A lot of that is down to the complexity. A luxury SUV even at 6 years old is going to have a lot more things to go wrong than a 6 year old basic runabout with no central console screen, no parking sensors and just a basic radio and some very basic analogue dials.
Though Jaguar Range Rover are notoriously poor build quality and in general will tank the average of luxury SUVs as that is all they make.
So when you drill in to actual statistics you find some Luxury SUV types have better reliability than many of the cheaper runabouts. Statistics are easily manipulated to prove any agenda.
To be honest it was a quick Google to provide some balance to the "I know ten (may not be accurate) people who all say their cheap cars broke" line.But the survey you posted a link for is for cars between 6 and 20 years old. So that means by your own criteria the current more complex “cheap” cars will be less reliable in future.
You also used one set of super wide statistics to prove SUVs were less reliable than cheaper basic small cars. Yet that is a very simplistic statistic that is utterly meaningless because people buy a specific make and model of car, not a generic class of car.
You need to look at the statistics of the year, make and model of the car you are going to buy, not some meaningless generic statistics for “all SUVs”.
You're right if I was actually trying to really drill into it and make a proper debate it's not the best data in the world but there we are.
like Yulaw said even at 4years sounds improbable that plugs could be gone w/o another reason .. but if you have another year on the warranty should have some protectionSo, update on the car, the shuddering I was feeling was actually misfiring. 3/4 spark plugs are done, being a consumable part they are not covered under warranty so I would be on the hook for £150 diagnostic charge and the work, lovely.
- had you put good fuel in it, sometimes, and is mpg off - did they categorically say what if any codes there were.
.. none ? less likely to be injectors/fuel-system -internets like looking up your medical symptoms V
google saying https://www.tucson-forum.com/thread...cson-limited.595/page-4#nested_reply_top_post
(stuttering I had had was a cam shaft sensor - diagnosed by the internet .... not sure if chatgpt gives advice here, if it has been fed on forums)
Didn't pick up on that, I would definitely say what I'm seeing is something more recent than 6 years.
