Not sure if its you asking or the guy that fitted a new kitchen and then ripped up the floor afterwards…….both seem very backward in their thinking.How much? And when?
Are you not a fan of sensible discussion?Not sure if its you asking or the guy that fitted a new kitchen and then ripped up the floor afterwards…….both seem very backward in their thinking.
?? only if it's over 5kw ? .. had my wall done cause mines a 8kw .. and we don't do doors downstairs .. still had to do it ..Cut a 10cm hole in a perfectly good wooden door as it’s a mandatory requirement for any room containing a wood burner or a fireplace.
It was that or cut a hole in the glass of a double glazed window or, even worse, bore a hole through a 50cm think stone wall.
French rules are different. Any fireplace/wood stove = 10cm vent.?? only if it's over 5kw ? .. had my wall done cause mines a 8kw .. and we don't do doors downstairs .. still had to do it ..
23 radsFlushed the rads with x800, put my makita pump on the playroom radiator feed to clear a blockage. Cleaned magnaclean, fixed magnaclean broken collet :/ and then reconnected.
Flushed again, refilled with x100. Checked all 23 rads. Will balance tmw morning.
Hate plumbing. Messy.
Right?? I need to look up hiring costs for a mixerBeen digging up the garden for DIY gravel drive and laying some slabs before the heavens opened. Mixing concrete in a wheel barrow isn't fun
Next to nothing. You can even buy them on marketplace, use them, and sell them for the same amount.Right?? I need to look up hiring costs for a mixer
