we survive with granny charger with 2 EVs currently. We're organised about the garaging overnight, but its never been an issue with a 2017 Leaf and an MG 5How many people survive with just the slow granny charger?
Yeah ok, might just see how we get on then. Decent wall charger is about 1.3K plus fitting.we survive with granny charger with 2 EVs currently. We're organised about the garaging overnight, but its never been an issue with a 2017 Leaf and an MG 5
I have the Enyaq, I get 300+ miles on long drives regularly.The point is that the -20% is exactly the same on the Enyaq in optimum conditions. It is no different on any other EV on the market at the moment because no one drives the WLTP cycle which is widely optimistic compared to the real world.
The big battery RWD Enyaq has a rated range of ~330 miles. I don't own an Enyaq nor have I driven one (or an ID.4) but there is not a chance on in a month of Sundays that you get 330 miles out of one when driven normally in the real world. All credible reports suggested they get 260-270 miles which is pretty much bang on -20%.
Incidentally that's pretty much the same the same as an AWD Model Y which has roughly the same sized usable battery but has nearly twice the power.
The only way I can see you getting anything close to the WLTP range in real world conditions is if the car has ridiculously low drag so they are not impacted as much by higher real world driving speeds compared to the WLTP test cycle. At this point you are talking about highly impractical cars like the Aptera or Lightyear which normal people will want to own.
I think they are about £900 now. At least got mine fitted through octopus for £800. They only offered Ohme at the time but they also has zappi and others on offer nowYeah ok, might just see how we get on then. Decent wall charger is about 1.3K plus fitting.
Yeah its a crazy bill to swallow. Unless you are doing big miles and avoiding a rapid charge (work etc) then it's just not worth it (other than for convenience).Yeah ok, might just see how we get on then. Decent wall charger is about 1.3K plus fitting.
I believe he's in NZ.I think they are about £900 now. At least got mine fitted through octopus for £800. They only offered Ohme at the time but they also has zappi and others on offer now
I make that $1300 about £625, so plus fitting is probably comparable. Do you have cheap electricity rates there, special overnight rates etc, as it might pay for itself quickly enough.Yeah I'm talking NZ peso.
Cheapest "Off Peak" rate i can find is about $0.146 kWh.I make that $1300 about £625, so plus fitting is probably comparable. Do you have cheap electricity rates there, special overnight rates etc, as it might pay for itself quickly enough.
My long term consumption is currently 4.1miles/kWh that’s 9000 miles and almost 12m ownership. That gives the car range easily over 300miles.
It's really not, the WLTP test cycle is the WLTP test cycle.I think the issue with Tesla is they are REALLY optimistic.
driven 275miles trips to wales, Lake District this year. All made with a single charge and still over 60-70 miles left. All on motorways sticking to the speed limits. I believe my average speed for the trips were around 60mph which is probably as much as you can average consider the traffic/road works/round abouts/traffic lights etc.It's really not, the WLTP test cycle is the WLTP test cycle.
Do you drive below the posted speed limits or just on slow A roads?
I'm just struggling to reconcile it as pretty much everyone reports the real range to be 260-270 and every other EV on the market 'real range' is 20-30% lower than WLTP (best summer to worst winter).
Biggest advantage in the UK is that you can then sign up to an EV specific tariff and get very cheap overnight charging. You can do it without if your car is compatible, but not all makes are. Having a compatible charger means you can have the tariff with any EV.Is a "Smart" wall box charger even needed? When you can program the car to only charge at off peak times. Just looking online as prices, the smart ones are twice the price. The Tesla Gen 3 wall charger is only $800
just spit balling and not suggesting I am right however I can imagine that even tho the wltp range is standard some cars will be easier to get closer to that number in real world than others, IE some may have better battery thermal control so be more affected by temp changes or some cars may do better at certain speeds etc. it's possible there is truth in what both of you think.It's really not, the WLTP test cycle is the WLTP test cycle.
. (resetting the onboard computer didn't do it)Is a "Smart" wall box charger even needed? When you can program the car to only charge at off peak times. Just looking online as prices, the smart ones are twice the price. The Tesla Gen 3 wall charger is only $800
The disadvantage being there is a lot more to go wrong with it.
I have a dumb "Chargemaster" point which I got free with my Zoe.
A couple of my work colleagues have "smart" chargers (can't remember the exact make, but 2 different ones), they've both had numerous issues with them losing network connection, "forgetting" the schedule, throwing up random error codes etc, all resulting in failed charges or charging outside of the cheap hours, whereas I've never had a single problem with mine.
The only "issue" it has caused me was when I was considering a MK1 MG5, which doesn't have any kind of onboard charge scheduling.
Of all the places that need chargers the supermarket would seem like the last place - 95% of visitors to a supermarket are surely local people within 10 miles of home who can and will charge at home? Why would you want to charge at a supermarket?
