I'm good as long as it didn't have cheese in it, that really throws my sleep off![]()
If it doesn't have cheese in it, is it really a meal?
i don't know, I automatically do IF as I don't eat breakfast, I wouldn't struggle to eat twice my body weight in 8 hoursTiming is important in the context of amount of calories in. If you’re limiting the opportunity to eat with IF, you’ll eat less.
Honestly, time wouldn't be a limiting factor. I can eat A LOT before I start to actually feel like I should stop. It's been my main problem and the reason I have to count calories.If you’re limiting the opportunity to eat with IF, you’ll eat less.
This ^^I wouldn't struggle to eat twice my body weight in 8 hours![]()
Ahh sorry, see here >>> https://forums.overclockers.co.uk/threads/ive-done-it-im-half-the-man-i-used-to-be.18633763/I'm not sure what 'doing a feek' is... (a quick search says he's not posted in this thread) and I'm not sure what you're asking for input about? Are you actually looking to slow your weight loss and get healthier?
This is the problem with human nature, people set goals which are far too big, so then to achieve these unrealistic goals they set unrealistic lifestyles because they want to achieve that goal in as quick a time frame as possible.Whilst some of us have dropped a lot of weight, real fast, I would warn against it. You need to think about changing your lifestyle rather than 'I need to drop X lbs in Y weeks' as when you get to the end, you could be in danger of going back to what you did before. If you can change your lifestyle, you're weight will then adapt and come into alignment with that new lifestyle.
For example, I'm lucky in that I found an exercise that I really enjoy. I cycled a lot when I started, I cycle a lot now. Does the weight keep dropping off? No, because I now have the body of someone who cycles a lot. The process happened quickly because I did drop calories to a lower point than most would, but only by a small amount (1,900 cals for a few months), so it was reasonably sustainable. (Now I aim between 2,200 and 2,700 cals) If I get injured and can't cycle, I'll be in trouble, but while I'm enjoying the new lifestyle, the weight stays in check.
If, on the other hand, you aim for 40k steps a day and 1,350 cals. Yes, the weight will drop off, but maintaining those two levels is unlikely and I would be worried your weight might start drifting back up.
Does that make sense?
Obviously, I'm not an expert and others will have a different view perhaps![]()
A lb or two did bounce back on after this, but I stepped off the scales this morning at 15ast 4.1, which means 10lbs since the end of August. At first I thought this was quite quick, but actually, it's about 1lb a week, which sounds quite a steady rate. Given I know how many times I've not eaten well at all, I'm very pleased with this.Since mid summer I've gradually risen a little, touching just over 16st in July. So, I've knocked 300 cals off my daily target and been a little more strict with myself. It's been quite a slow process and seemed to be stuck at 15st 9 for 2 or 3 weeks and then in the last two days 3-4 lbs have finally dropped off, I just stepped off the scales at 15st 6.1 (Fri I was 15st 9.6). Mind you, I know how this goes, there's a chance some of this bounces back on as I rehydrate and such over the next couple of days. Let's see I guess.
I do worry a little that I get too obsessive though. Yesterday I snacked between lunch and dinner (300 cals of peanuts) and had the extra bits in the evening that I've been trying to remove and I felt like it had been a bad day... I mean, I guess it's not bad to keep an eye on myself, but at the same time, it was really nothing and I let it make me feel a little bad. Mind you, then I stepped on the scales this morning and felt good again, but I don't want my mood tied too closely to this. (Although tbf, it's not that big an effect on my mood) Do others in this thread have that issue?
Feel your pain..no chocolate shall ever be half eaten...I think I’m going to have to go back to low carb again. It’s the only thing that seems to work for me as it automatically rules out any sugary snacks which I am hopelessly addicted to. Can’t seem to find a happy medium, it has to be a whole bar of chocolate or none.
