- 14 Oct 2005
- Pembrokeshire
@gamerTM21 definitely creates battery anxiety! Even just playing some Forza Horizon 5 on my break at work (in "performance" mode as hadn't yet faffed with other settings) would consume half the battery within 45 minutes. Not very portable if I need to connect to power within an hour of playing.
Whenever I used it at home I was tethered to the power cable.
I get owning multiple handhelds, but you can only play one at a time. I totally understand owning a PC handheld and a Switch, of course, though the former can emulate the latter if you aren't fussed about Nintendo Online...
Having just looked the Odin 2 is an Android device. I guess there are Android games you play frequently?
From my short time with the Legion Go, I think the older generation 15W Ryzen chips (and the Deck APU) is the sweet spot for gaming handhelds for the foreseeable. I imagine the Deck 2 will also target a 15W TDP.
