- 26 Dec 2005
- Paisley
you can easily add it to update allHope n64 is official soon. Haven't dabbled yet.
Yep I just haven't got around to it yet. Happy to wait though really.you can easily add it to update all
Do they have a seperate updater like the PSX core (pre-release)?if you want to just add this line to downloader.ini
[n64_dev]db_url = https://raw.githubusercontent.com/RobertPeip/Mister64/db/db.json.zip
there was but it got removed when the above line was added.Do they have a seperate updater like the PSX core (pre-release)?
Sounds interesting. The more scalers on the market the better.Bit of a random question but, would you be interested in a MiSTer that could also be used as an original console upscaler all in one box? The only downside would be, you would have to swap out the SD card with another depending on usage.
This would allow you to scale 6th gen consoles too using a SCART input.Mister has a good scaler, the only thing it cant do currently is scale up to 4k - the mars will do that though so it should be the all in one scaler/all in one that would suit everyone.
But you could still only scale up to 1920x1440 with the de10 nanoThis would allow you to scale 6th gen consoles too using a SCART input.
SCART in to the DE10-Nano and HDMI out
Is that the max it would allow? Either way guess if you didn't have access to another scaler, would be a good way to upscale original hardware outside of RT, OSSC, Framemeister and the GBS-C.But you could still only scale up to 1920x1440 with the de10 nano
Correct but if you don't have another scaler, you can use your MiSTer for Dreamcast etc tooBut you could still only scale up to 1920x1440 with the de10 nano
Sneak peek at something I've been working with Wizzo on...
How would the scaler work on the mister, ive been trying to wrap my head around it?
That's pretty cool. Can you choose which 10 games you want?
Still after a metal case for my Mister...
