12 Dec 2023 at 16:59 #21 gam3r gam3r Soldato OP Joined 20 Jun 2005 Posts 3,826 Location London.. Zeebedy said: so your currently using the included cooler? Correct? Click to expand... I'm using the LS520, so the AIO.
12 Dec 2023 at 17:07 #22 Zeebedy Zeebedy Soldato Joined 28 Jan 2011 Posts 8,606 gam3r said: I'm using the LS520, so the AIO. Click to expand... hmm, I’m 99% sure that for that AIO it is quite high. when I got my DeepCool AIO, I replaced the paste from the get go, rather than use the standard stuff.. but that wouldn’t make a difference of like 30c or so that your seeing..
14 Dec 2023 at 10:20 #23 Wing-Man Wing-Man Permabanned Joined 30 Dec 2021 Posts 3,642 Location Yorkshire My basket at OcUK: 1 x B Grade Alphacool Core Ocean T38 CPU Water Cooler - 240mm (SKU: BG-0A4-AC) = £49.99 1 x B Grade Arctic Liquid Freezer II High Performance CPU Water Cooler - 240mm (SKU: BG-04G-AR) = £52.99 1 x B Grade Phanteks Glacier One 240MP All In One CPU Water Cooler D-RGB Black (SKU: BG-08P-PT) = £59.99 1 x B Grade be quiet Pure Loop 240 Performance CPU Water Cooler - 240mm (SKU: BG-148-BQ) = £64.99 Total: £227.96 (includes delivery: £0.00)
15 Dec 2023 at 10:30 #24 w00dy85 w00dy85 Associate Joined 14 Feb 2008 Posts 1,285 I would go with the Artic Freezer II, has a built in fan that helps cool the VRM and a thicker radiator. I have bought 2, 1 in my PC and 1 in my son's and would highly recommend them and it should also come with MX4/5 thermal paste. Last edited: 15 Dec 2023
15 Dec 2023 at 10:32 #25 Wing-Man Wing-Man Permabanned Joined 30 Dec 2021 Posts 3,642 Location Yorkshire Yep the AF2 is a super cooler if you have room for the thicker rad.
15 Dec 2023 at 11:53 #26 w00dy85 w00dy85 Associate Joined 14 Feb 2008 Posts 1,285 I also fought to say in my sons PC, it's a AF2 240mm cooling a 7800X3D
