- 21 Aug 2010
They may be able to remove the bath and then cut the tiles in situ would make a hell of a mess but could work.
Because the plumber has been a nightmare turning up. I thought if I can fit it myself then the bathroom would be finished.Why are you fitting the side panel?
I haven't really kept track properly, but he's done roughly 7 days work. He is a mate so won't rip me off (I hope) I honestly have no idea how much I owe him, over the last 2 years we have lived here he's fitted several radiators, added some plumbing for my fish tank. Changed the kitchen tap. Lent me tools to fix small problems etc. And I haven't been billed for any of it yet.That's nuts. I hope you've paid little (compared to expense, not compared to 'expectation'). Sounds like you've done a bulk of the work to give them an opportunity to top up their earnings around their bigger jobs.
I'd solve the problem by trimming the bath trim at this stage. I know it's a "bodge" but the mess around may not be worth it.
The alternative, is knock the few tiles off, level the the bath full of water, then get your tile man back to refit with new tiles.
Appreciated, I'll post a pic of the full room when I get chanceP.S. it looks mega!
It is so damn close I'd be tempted to gently heat it..........
Depends what you do in the bath I guess?Is there a risk it might squeak after cooling though?
they're not floppy - have one - but w/o a former behind, of some sort, it might become so;I guess you mean strength of the panel itself. So trim the bottom to maintain the rolled over lip at the top for strength. It will always be a floppy pos panel anyway.
Best point of the thread - if you were gonna silicone anyway, it won't make any diff! Hot glue a baton on the floor to stop flex. Job done!Trim panel, silicone the edge (which you would fo anyhow).
