- 25 Jun 2006
Boneshatter something for me
just found him for first time and managed to kill him with LA DE build, only have 3.2k hp so was expecting to get one shot. I think my cold damage was slowing him making it easier
really enjoying the league mechanic even though the build is a bit squishy for it. It's opt in so I'm only doing it in lower red maps, in T16 with any damage mods it would be a bad time
Playing in HDR game looks awesome for sure.The blue wispy things are a tad hard spot.
ice shot convert only 60% to coldI've played a fair amount this league and got a decent build going I'm happy with, although it does struggle with high red maps that are juiced with the league mechanic. Anyway, one thing I've noticed is that I am getting wrecked in phys reflect maps even though as far as I can tell I'm doing no physical damage. Can anyone help spot the problem? Here is the PoB link https://pobb.in/lwIBeF_gehv2
The only thing I can see in calcs is the frenzy links generate some physical damage from...somewhere? I just roll over it but it would be good to understand what's causing it. Thanks!
Thanks, I see that but in PoB I see the belowice shot convert only 60% to cold
Hiya, its one of the crafting recipes you get from unveiling rings at Jun. You can search for unveiled rings (Veiled = Yes) on the trade site and look for those with unrevealed prefixes, I think specifically the prefix Eleon's is what you want. I then looked for rings with stats I wanted with an open prefix on the trade site.Hi Brok
How do you get the non channeling skills craft on your rings?
which suggests to me there should be no physical damage done. Or am I misreading it? Thanks for any light you can shed on this![]()
Its exactly this.I think it could be your Manaforged arrow/Frenzy setup that's doing the damage. It's only gaining the 40% conversion from the mastery, not the same extra 60% like Ice arrow does.
Its exactly this.
Manaforged/frenzy does physical and only takes the 40% from the tree.
To completely move away from phys damage you need cold convert gloves, you can get them from alva missions in the temples + the eater implicit on gloves should help a ton.
So generating your frenzy charges and power charges is what is hurting you.
In pob, go to the calc, change the skill to your frenzy setup and you will see the phys damage, even though you are pretty tanky and can take phys hits, attack rate + Leech does not out perform the amount of damage you take from physical hits on frenzy.
