I doubt you’ll get a softener into the cupboard under the Belfast sink.
Scratch that, I’m going to go out on a limb and say you will not, even if you cut the bottom of the unit out and sat it on the floor.
The 2L boiler unit on my Qettle tap only just fitted and it’s tiny by comparison (it has top mounted pipes). The Qettle water chiller didn’t fit and we had to send it back in the end as there wasn’t anywhere else to put it. It also has top mounted pipes and it it’s taller than the boiler unit.
The cupboard next to the sink is only 400mm which 80% is taken up by the softener and the other side of the sink is a dishwasher.
I don’t have a model how about a picture?
Edit: the water2buy softener doesn’t need an external emergency overflow adding, it has an internal float valve to stop it filling if the water level gets too high. You just need a waste discharge which attaches to an appliance fitting alongside the water in and out.
