- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
Yep - if you can imagine it, you can print it! I'll have a Google around and see what's out there and I can design something tomorrow.If you're able to print cable combs
The enclosed ones look better
And the cables don't pop out like open ones
Not sure if you could either print them hinged?
Or in 2 halves that click together?
It's nice as you can print it absolutely perfectly to fit every corner and crevice, so worth doing I say!
