Spec me an LED Torch
Fancied a new torch to play with on dog walks during the winter nights so treated myself the Lumintop Mach V2 4695.
His much was that beast?
Lumintop Mach turned up yesterday, the battery is a beast.
From left to right, 18650, 21700, 26650, 26800 and 46950.
https://i.~ibb.co~/F8Ctf45/01.jpg
https://i.~ibb.co~/vH4bPdr/IMG20231215122720.jpg
https://i.~ibb.co~/VHGCsWQ/IMG20231215122733.jpg
Can anybody recommend a bright long range torch​
..for somewhere between £60 and £100.
Thanks
[mod note, merged, the highlighted text is the old title - Wolfy]
Thanks
Spot or flood...or both?
I just bought this:
And it's a superb torch, has flood and spot (plus RGB :P).
Only paid £104.99 for it though, when it was on offer.
The normal colours were on sale the other day for £140.
I just bought this:
And it's a superb torch, has flood and spot (plus RGB :p).
That would have done nicely for spot and flood.
I have 3 Sofirns: This one is a perfect multi-use torch, insanely bright and comes with everything, plus 30%
I have that torch you linked, but please do use the Greasemonkey script called "General URL Cleaner" :D
I bought this: https://www.amazon.co.uk/gp/product/B0BPY2RYLW/
Very pleased with it. Zooms from Flood to spot.
I gave your post a 'like' too because you posted a clean Amazon link unlike the n00b above you :p
Not my fault the forum doesn't parse amazon links like it does for other sites!
Big ole thread here about torches they might be worth a gander
