- 7 Mar 2005
- Northumberland
1.40 today. Another poor show... Oh yes its winter
Yes, you just stop that right now!Another 10.2 here today, good start to Jan at this rate I'll surpass December's total by mid month. But that's probably jinxed it.
11.7 kWh generated and 4.3 exported.
If you mean the exporting, I always try and export some at peak rate, but due to saving sessions only export between 16:00 & 16:30, even if the batteries aren't full, but I stop if I get down to 55% SOC, although I had 74% left at 16:30 today which is a novelty at this time of year.At winter time that's amazing.
10.1 kWh for me, now that is impressive off my little old array11.7 kWh generated and 4.3 exported.
It's the original array generating most of the power at the moment, yesterday it generated 9 kWh, which means the garage array only added 2.7 kWh. The panels on the garage are at 10 degrees east/west, and also shaded around midday by a neighbours tree, due to the low height of the sun.Gen too but I guess your not impressed yourself as its the additional array adding to the total now. What would the old setup do (on its own) this time of year by the way?
