Solar panel production figures
Another 10.2 here today, good start to Jan at this rate I'll surpass December's total by mid month. But that's probably jinxed it.
6.8 today by miles best of 2024 so far and its about the max I can get since it was cold and clear today.
Tomorrow forecast right now is just the same.
I am now 1kwh behind 2023 at the same point, and 10th jan 2023 was a horribad day so hopefully tomorrow I smash past the 2023 month to date number.
The forecast isnt looking that nice past tomorrow however...
At winter time that's amazing.
If you mean the exporting, I always try and export some at peak rate, but due to saving sessions only export between 16:00 & 16:30, even if the batteries aren't full, but I stop if I get down to 55% SOC, although I had 74% left at 16:30 today which is a novelty at this time of year.
Gen too but I guess your not impressed yourself as its the additional array adding to the total now. What would the old setup do (on its own) this time of year by the way?
It's the original array generating most of the power at the moment, yesterday it generated 9 kWh, which means the garage array only added 2.7 kWh. The panels on the garage are at 10 degrees east/west, and also shaded around midday by a neighbours tree, due to the low height of the sun.
Look at what Oldman generated with a 2.94 kW array yesterday, his is all south facing. 10.1 kWh, he's only 13 miles away from me as the crow flies.
