well the formula is straightforward, load up on magic find gear really.
and all 3 wisps gathered.
go ham on mobs but one needs a strong build to deal with the mobs for sure
I'll keep trying
There is a premium Unique tab which allows you to store one of each unique in it. It's a pain though as if you set it with unique affiinity then every time you get a dupe you get an error trying to move into your stash unless you remember to shift+ctrl+click to override.
I don't think so, I don't really look at standard as its just a sea of remove only tabs that I can't be bothered to sort through! You could I suppose fill up some quad tabs in league and name it with the league name so when they copy to standard its partially organised already.I've got the unique tab, just wondered if you could have one that saves all your uniques every league, and still have one for the current league if that makes sense?
Enjoy, hardest part is choosing which flasks and affixes to use, so many combinations!
It's beautiful
I'm having trouble deciding which build to switch to. Either my usual Berserker Flicker - done it so many times I know how to build it easily, or maybe something like cold BVEnjoy, hardest part is choosing which flasks and affixes to use, so many combinations!
MF yea, drops are so common, I got 4 or so not even doing serious MF.Aegis is the most surprising one for me. I remember last time I played RF a few leagues ago, it was 20+ div at one point. Now it's literally 5c. Is that because of the MF hype or did they change the drop chance/pool?
Hit 98 today, 38 challenges done.
question to do a lev 100 or not, will see
Yea most L100 are just 5 ways.I have got to 99 but it was fairly dull playing safe through most of 98 so not sure I have the appetite to push through 99 as well.
I did just get a foil Fulcrum from a voidborn key so perhaps the game is trying to tell me what to try next!
Yea running one such build with champion, tanky and dps.Just Doryani'd a 20/20 Penance Brand of Dissipation to 21/20 first try. 30 div profit! Wondering if I actually play it or sell it. Still can't decide on a build. Still just blasting essences. Got 100 div + Mageblood saved up and dunno what to do with it.
