My Zotac 4090 has malfunctioned ? I think it has
26 Jan 2010
So all of a sudden my Zotac Amp Extreme 4090 suddenly developed a malfunction
During web browsing my GPU suddenly decided to change the resolution from 3440x1440 to some blurry 720 resolution, when I tried to change back to the default it would not allow me
Nvdia control panel doesnt work, and via device manager display adaptor its showing me the yellow warning triangle
So i try to install new drivers, it fails and hangs
On restarts the damn monitor sometimes doesnt discover a signal from the GPU
HDR option greyed out
So I install a back up GPU, 3080ti and itg works perfectly, bang in the 4090 and same crap, lame blurry resolution and my Asus Motherboards Beeps 1 long 3 Short, this means GPU error
So seems to me after 14 months of light use the card has malfunctioned
now who will deal with the warranty? the retailer or Zotac?
Anyone experience a nightmare?
How long is the warranty? Usually its 2 years, if it is you'll need to go back to the retailer.
Do graphics cards still have the brittle solder issue,after changing to lead free years ago? Or has that been resolved now?
If its under warranty speak to Zotac, if not, maybe the oven trick if the above is still the case??
Ok so Ive taken the card to my work PC and it displayed the same symptoms, after a few restarts it suddenly worked, so I boxed it back up and took it home
Now as soon as Ive connected the card I get the same issues, but this time im getting windows HDD check pop ups, and BSOD, some times when it goes to desktop my mouse keyboard wont work or its the same blurry screen
Installing a 3080TI has zero issues
So I call the retailer and asked for an RMA
Now they said to me because the GPU is 14 months old and the Zotac Amp Extreme 4090 is no longer in circulation they will deduct 25% of the value, so thats about £400 from the £1950 i paid for the card
I was outraged as I asked for a repair or a replacement, they said its Zotac that deducts because of depreciation.
When I spoke to the retailer they also told me its consumer law
I can confirm that the 4090 displaying issues wasn't my fault.
I think its unfair that I have to pay another £400 because my card decided to malfunction and the retailer will only refund £1450 from the 1950 i paid
Anyway Zotac said this:
I’m not aware of any policy as you’ve described.
The only reason I can think of that the 4090 cannot be replaced may be to do with the US export controls on GPUs for AI use in China. Unfortunately the 4090 was caught in this, and as 90% of 4090s are manufactured in China this might be causing a supply issue until the production base can be moved.
The above has nothing to do with my RMA
Also if this is true then Zotacs 5 year warranty is pointless because they will say not in circulation, deduction due to depreciation
The depreciation thing if a card is not in circulation is true. It also depends if the store stocks it anymore to provide a direct replacement. You could ask the store to RMA to Zotac with your email, but you might end up waiting months.
After 3 years you would have to RMA directly with Zotac as well. As the retail warranty is only 3 years.
ur right, could take longer with zotac, i posted on reddit and someone said the retailer is doing me over.
what kind of consumer law is that
That's outrageous. You should approach the tech press with that.
