Yes, it kind of seems logical that if screwed into the case that there should be no lag but in practice this is not how it is.It would make sense that they may crack along the pci-e connector area. Weighty card held in with just a couple of screws at one end. I think I'd always be going for a support for a 4090.
My Gigabyte 4090 came with a beast of a support bracket I had to screw into the motherboard standoffs and then screw into the card. I could probably stand on the card and not move itWhere there's a blame there's a claim, but arguably you could also say that anyone buying a 4090 is an enthusiast, they should already know to use a supplied support bracket. Obviously with an FE they don't come with one so that's on Nvidia, but basically all AIBs come with one? Or is it just a handful of AIBs?
Personally, If I was buying an expensive, upper midrange GPU, I would want it to focus on how it compares to previous generations of expensive GPUS, could not give a rats ass what is going on with an OLD tech based PS5.XBOX, if I did, guess what, I'd own a console LOL....Hurr durr maybe it's because their review comes out well after other sites and these others sites have released hundreds of reviews comparing the 4070 super to other GPUs but not a single one has compared to the consoles, maybe just maybe DF is looking for something to stand out amongst the crowd because they have the tools already to accurately test consoles and for years now DF has been a console focused channel so god forbid they continue to focus on console content
Mine wasn't a fancy screw in one, but it is magnetic and is rather sturdy too:
Still lol at the size of these cards...
I'd say no, when you hold the card, the bulk of the weight is on the opposite side of the PCIe connector as that's where all the heatsink weight is bearing over. The connector area cracks due to the weight of the heatsinks on the opposite end bending that PCB area whilst in the PCIe slot as northridgefix demonstrates in the video posted yesterday. The area my stand is holding the card under is the exact area where you want to have support as that's the main area of weight bearing, by doing this the entire card rests in a more balanced way and the level of stress on the PCIe connector end is what would normally be expected with a much smaller card without a bracketSee, this kind of support now has me wondering. Whilst this would help alleviate torsional stress on the PCIe connector due to sag, does it help alleviate the shearing stress from pure weight.
Basically, should there be another support underneath the card, near the PCIe connector too?
A lot of aib cards aren't as stiff as coolers aren't a solid hunk of metal unlike FE versions. In effect said AIB cards have quite a bit of flexibility and put nasty torque on the PCB right by the pcie slot. Also, many seem to be damaged when computer is being moved. I'm both cases support of some sort for the card helps a lotI seriously don't understand this. The 4090FE, with it's full three-slot backplate, properly fixed to the card chassis across the full width, is totally solid and just doesn't move at all, let alone sag.
I don't understand how these can be "cracking" when there's no flex at all.
Same and I've been using it since day one. All the previous cards I had sagged over time aside FE ones and AMD stock ones.My Zotac 4090 came with a heavy duty metal support bracket, takes basically all the weight off the PCIe connector.
I don't believe I've seen even one FE cracked but if that happened I would suspect it's different reason - pure weight and transporting it inside PC without proper safeguards. Shaking such big mass will cause some damage to the PCB or connector eventually.If FE cards are indeed cracking also then I'm forced to wonder how/why as there shouldn't be any appreciable torsional stress on the PCIe connector as the card isn't twisting or rotating around the connector.
Hence why I wondered whether it's just pure weight creating a shearing force at the connector as this is providing support to the full weight of the card.
Oh yes in terms of FE sure, I thought this was about AIB cards like the Zotac![]()
It's not even about the back bracket, big chunk of metal like on 4090 FE one weights enough to have quite large inertia - that would likely be enough to bend something at least when shaken.Yes, until now I believed it was only AIB cards that had exhibited this issue and from that I inferred it would be those where the "chassis" of the card isn't properly attached to the rear bracket allowing a large degree of flex/sag.
It was only that someone earlier commented 4090FE cards were also cracking which surprised me and started me wondering how and why.
Incidentally, in that northridgefix video, the number of Asus cards was shocking.
+10% MSRPZuck announced Meta is buying 350k H100 Nvidia GPUs for its AI
Zuck is trying to make Jensen richer, think of all the leather jackets he can buy!
350,000 GPUs * $30k each. Though this order size they probably get a discount, maybe $20k each? Who knows, it's Nvidia maybe it's full price. Anyway that's up to $10 billion in revenue for Jensen, from a single customer
And this one order will generate more profit for Nvidia than they make in an entire year selling gaming GPUs to us peasants
