Thinking about wetroom / new bathroom.
Since the above I did a 2nd screed pour as the first wasn't enough, I've also been sanding and filling the roof lights as in this room and adjacent utility room have previously had issue with condensation and paintwork blistering /bubbling
Also got my tiles in now. Gone for the same ceramic tiles i have in other bathroom (they're porcelain for floor).
I still havent bought a tile snapper for the ceramics. Tempted by a screwfix type job.
Rooflight just needs some painting to touch it up
Tiles in, this is just shy of £1k worth :X
Taped the joints near the wet areas. I ran out of tape here but I think this is sufficient
First couple tiles I forgot to back butter and to be honest it's not perfectly flat /level but if you squint it's mint!
Just hoping that no tiles lift as I knock the clips off as I'm worried there's a couple voids. Should have used more adhesive throughout it to be honest.
6pm darkness angle grinding is OK right?
Does anyone know if wood or mdf architrave better in a bathroom. I need a very short (~44mm profile that will go right up againsst the shower screen and I can only really find a couple in Travis perkins
Tiles held together! They feel /look pretty good tbh I'm not going to grout them until the end when I've done walls.
Set up timbers for first walls and setting out. Was a bit difficult balance to get an ok height for worktop, niches and tall ceiling
Looks like a fine job so far.
Why did you tile the floor before the walls out of curiosity? I think normal process is to tile walls up from batten, leave bottom row, tile floor, tile bottom row. This reduces the chance of snots on the floor.
Also the missing tape - can you not get some more and cover those bits? That would probably weigh on my mind.
I'll just put a couple sheets down on the floor. Reason I did the floor first mainly is I haven't bought a Snap cutter for the ceramic wall tiles yet, plus means I can put architrave on top of the tiles
The tape is all over where the shower is, the only untaped bits is the opposite wall which won't really get wet.
What water proofing bits are you using buffman? Is there something alternative to the tape/paint on? I'm not far off your stage.
Marmox boards, 20mm on dabbed wall and 12.5mm on other walls. I later found out you only need 12.5mm when dabbing it.
The waterproof tape is an eBay one I posted back in this thread somewhere. The marmox tape is pretty expensive. The prefab taped corners might be marmox
Thanks.
I ended up with an Amazon kit my brother said was OK and he'd used before (£40 quid all in). I've got a niche from eBay, which I might fully tank as well just in case :cry:
I've got 6mm and 12mm boards. I'll use the 12 on the false wall and the 6 on the floor. I probably should use 6 on the clinker wall as well; probably didn't need so many 12s and have too few 6ers!
I wonder if I need the corners for a shower bath or silicone is enough?
Thanks.
I would check if the 6mm boards are too flexible, I think they're only really good for over boarding a floor. Even then I think if doing a floor again I'd use hard backer. The 6mm boards I had from marmox previous felt a bit crap.
Yes I would taper the corners in a bath shower. I even did it in just a bath in upstairs bathroom.
That's bang on, very helpful thanks man. I'll do as you suggested and put the 12mm everywhere on walls, and then 6mm is just over boarding my brand new 18mm floorboards so perfectly flat glued and screwed.
I've always struggled to understand why thinner boards are used on the floor vs. the wall. I would have thought the floor boards would need to be at least as thick as the wall boards; they are walked on. What am I missing?
The floor should have zero voids, and effectively there isn't any span and like most materials will be strong in compression
When it's got to span say a 400 centred stud wall and hold up tiles and/or take any impacts it needs to have rigidity to it. Same with a dabbed void or anything similar.
To be honest those 6mm marmox boards I posted in above (I think "tile backer" rather than the dual backed "multi boards" boards I wouldn't use again, Id just buy hardie backer, the boards seemed very flimsy
Fitted the door architrave and some tiles today. Got a ceramic "snap" cutter and cuts don't seem brilliant to be honest not sure if there's a knack to it (keeping straight cuts) they're relatively clean the cuts but tbh I can get it better with a grinder.
I was a bit suss but when the boards came, they weigh a tonne. Very substantial and they are under compression versus the wall boards. Also with 18mm "loft boards" the floor height won't be silly versus the carpet.
Today though I realise I've made a bit of a balls up with the vertical setting out in the niche. I realise that there would be a slither at the bottom of the niche so there's a couple options
1. Keep the slither at the bottom
2. Do what Ive done as indicate and run it full height in the niche (loses the grout line)
3. Fill out around 20+mm and bring "up" the niche so the bottom is flush with the tile
Not sure if it's worth doing option 3.
Here's the example one I have upstairs, think I may manage to get my mitres a bit tighter than previous.
Done some more tiling and cut the last ones but not adhesived on yet....end is in sight. I've run out of level master clips but think I just yolo it
