ROG STRIX B650E-E GAMING WIFI BIOS 2412
Version 2412
11.24 MB 2024/01/30
"Update AGESA version to Combo AM5 PI 1.1.0.2b
Before running the USB BIOS Flashback tool, please rename the BIOS file (SB650EE.CAP) using BIOSRenamer"
Is the WI-FI disconnect issue resolved on this board now? As it's likely to be my first AM5 board.
.Using,What ram is everyone using with these?
CMH32GX5M2B6000Z30KWhat ram is everyone using with these?
ROG STRIX B650E-E GAMING WIFI BIOS 2413
Version 2413
11.24 MB 2024/02/07
"Disable STAPM of AM5 Ryzen™ 8000 processors to improve system performance.
Gskill F5-6000J3038F16GX2-TZ5NRWhat ram is everyone using with these?
Had mine for almost a year now. Never had any coil whine, only problem is the rubbish NIC.
.I think mine might have stopped working correctly when I started using Windows Power Saver Mode, I cannot be 100% but it was about the same time. Anyway, the USB NIC works fine so I have no desire to use the Intel one ever again. I need a stable NIC for work so not going to risk an Intel NIC.I thought I would give you an update on my Intel Nic, moved from Virgin to Community Fibre ISP in Jan due to being cheaper and also end of contract with Virgin, anyway been rock solid on my 1GB connection, had my new PC around four months now so long enough to see if any issues would appear.
Using latest driver and BIOS FYI.
Cooler wise for other users using a Deepcool AG500 air cooler on EXP1 setting , does the job and no heat issues, I do game a lot.
