Never been able to wear wellies. Just too little support for my **** feet
These are just so comfy, I think it's a sizing fluke but almost a mold of my feat with no tight spots, lots of support very light also
Most of my local walks are deep mud,marsh so I really need them, also trebarwith the other day had to wade through the swollen stream to get on the beach.
Never had foot issues,shin splints once on my Camino, nasty
Really need some new walking trainers though
Edit, can't find a definition of.shin splints was ,told I had them edit found it
Some more coffee from Origin and a free tin to keep it in. Coffee is "Stronghold".
Aww yisss. Such a great watch. The box is epic. I swapped my strap for the later model but from King Seiko.
I got myself some 300 quid rent boy boots. Not sure I can pull them off but going to give it a go.
Are Loake Imperfects their “seconds” and if so what kind of reduction usually? Did you get them direct?
There was a pop-up shop down the road so I paid half. That is about my limit for any shoes tho tbh. I have about 7 pairs of Loakes, all going strong after 6/7+ years, so hopefully these, despite having elastic, will be no different.
Yea, Loakes are decent and so assuming they are looked after these should last just as long. Good find.
how are you finding the tapo? was looking into this for new upgrade
Not used as of this time as I still have some decorating and room changes to make, but can report that they pair up quickly with the app + Alexa and the Smart plugs I am running them off.
I've got 3 of the C200 or C210s (can't even remember). One of the three has fallen 2m+ about 20 times (I use it irregular and forget the start up routine makes it do a twirl and a dance, meaning it falls off of the ledge lol). All bullet proof. Super reliable. The app is brilliant. 10/10 would recommend.
Just checked -- September 2020 is my earliest.
They make lovely shoes. I wore some every day for a few years until they virtually fell apart from the inside. I got some from my wedding that were too big, but therefore much cheaper, and I’ve not been able to wear them since. Lovely shoes though…maybe my feet will swell when I’m old and they’ll fit nicely.
I can attest to this, i've got most of the Tapo ecosystem now, really reliable and great value too.
I have a sneaky suspicion that Tapo and Eufy all originate from the same factory, I guess it comes down to which vendor has the best deal at the time of purchasing :)
Blowy blowy thing, very impressive, I shall no longer require canned air and it has a sexy braided cord, life goals..... :p
Cheap little 3.5" screen off Ali Express for like £12 delivered
Cheap skin for my Ally Rog to see what I thought of skinning it - £6 delivered (yes I left the bezels showing, it was very weird with them covered with the pattern to my eyes.
