I just have it set so my screen turns off after 2 minutes, no screensaver for me. It's one of the windows settings under 'Power'.guys, are any of you using a screensaver? or you just turning off the monitor when not using it? if i opt for screensaver, shall i use solid black? or there is no need for all of that?
It will automatically do a pixel refresh for you. When you turn the screen off, you'll notice the button goes green (or yellow? idk I'm mega colourblind) and flashes for 4/5 minutes which means it's running a pixel refresh.I turn it off, should I do a panel refresh after I'm done gaming?
Mine is set to go to sleep after 30 minutes of in activity and my PC after 2 hours.guys, are any of you using a screensaver? or you just turning off the monitor when not using it? if i opt for screensaver, shall i use solid black? or there is no need for all of that?
I use a solid black screensaver after 5 minutes, but that's only because there's something a bit odd in my setup that means if the screen actually goes to sleep it hangs the desktop for a good 30 seconds on resume. I'm sure its fixable but I'm just working around it at the moment.guys, are any of you using a screensaver? or you just turning off the monitor when not using it? if i opt for screensaver, shall i use solid black? or there is no need for all of that?
I don't like a blank screen so I use wallpaper engine with an animated scene: Shimmering Particlesguys, are any of you using a screensaver? or you just turning off the monitor when not using it? if i opt for screensaver, shall i use solid black? or there is no need for all of that?
Just using it normally, split windows on the desktop etc. Pixel refresh happens regularly enough for me not to worry and the 3 year warranty is always there. I feel like if I start to worry about how I use it it'll take all the enjoyment out of it.I think it's fantastic, I've come from a 4k IPS to this age the HDR is on another level. Pubg doesn't use HDR so the improvements are less but games with HDR are just so much better looking now.How are people finding the monitor ?
You can try the new RTX HDR setting with Pubg ?I think it's fantastic, I've come from a 4k IPS to this age the HDR is on another level. Pubg doesn't use HDR so the improvements are less but games with HDR are just so much better looking now.
Loving it, i upgraded from a DWF and the extra resolution makes all the difference.How are people finding the monitor ?
Yes, a mate of mine told me about that iirc that driver is still in beta?You can try the new RTX HDR setting with Pubg ?
I noticed while playing Alan wake 2 the flicker that my DWF had in certain areas was less apparent more stable on the 32", also yellow and red colours seem to stand out and pop a lot more, motion has improved also over the DWF.Aside from res/clarity, noticing many other improvements over the DWF?
Massive step up yes i had a 2716DG TN many many years ago, your in for a treat colour wise and contrast and motion wise.I've had the AW2725DF in my basket for the past week and I think I'm about to pull the trigger. How are you guys finding it? Will I notice a massive step up from my 2716DG TN panel?
