Ha, as i said nvm. A bit too risque. It was a poor joke.
Btw the Nvidia App has updated today, no changelog yet, it loads this page after the update:
Back on topic, you guys won't believe this, sorting out my wardrobe this morning and found my old leather jacket. Maybe the way of the Jensen was destiny all along?
You obviously don't ask nicelyAnyways graphics cards. B grade prices. They are the lowest prices they will accept. (800 for 4080 **** off)
800 is there lowest( ive bought many items in the past). They are worth 600 max currently imoYou obviously don't ask nicely![]()
£800 doesn't seem so bad. It's that or a new 4070 ti super for the same price. It's the 90 day warranty that would stop me.800 is there lowest( ive bought many items in the past). They are worth 600 max currently imo
800 give me a break ffks£800 doesn't seem so bad. It's that or a new 4070 ti super for the same price. It's the 90 day warranty that would stop me.
Had this come today.. As they say "Better Late then Never"
That musta stung the old ring a bit!
I see you're sig says you also have an Evolv-X case
I spend many days thinking if i should buy a 420mm AIO to go in the front or a 360mm AIO to fit in the top![]()
I gone for the 420mm to try, But i may change to a 360mm in the top
