NVIDIA 4000 Series
Soul Revolver, was quite expensive I recall from 2014, back when my GPUs at the time were:
2013-2014
EVGA GeForce GTX 780 3GB
Sapphire Radeon R9 290X Tri-X
2014-2020
MSI TwinFrozer V Geforce GTX 980 4GB
:cool:
Back on topic, you guys won't believe this, sorting out my wardrobe this morning and found my old leather jacket. Maybe the way of the Jensen was destiny all along?
Surprised you have time to work out with the amount of screenshots you post! :cry:
That musta stung the old ring a bit!
I see you're sig says you also have an Evolv-X case
I spend many days thinking if i should buy a 420mm AIO to go in the front or a 360mm AIO to fit in the top :cry:
I gone for the 420mm to try, But i may change to a 360mm in the top
I have a 360 aio in the roof of mine, had it in the front originally, also have a modified front plate to give more airflow into the case.
