- 5 May 2004
- Northern Ireland
Most of the Garmin Forerunner watches use their own maps, are you set on Google Maps particularly? But yes, routes built in Garmin will give you turn notifications. Do you have a budget in mind? What about buying something second hand, and see if you stick at the running?Starting to get more into running and looking to get my first Garmin smartwatch but theres so many models out there. Im looking for something basic but functional so something like a Forerunner 55/255 perhaps. Does anyone know if these can be linked to your phone to provide turn by turn navigation on the smartwatch via googlemaps on the phone? From what I can see its only the higher end Garmins that have maps built in for turn by turn navigation?
not been able to properly run since September time ish, ankle seems better but run down post wisdom teeth/ Coronectomy . 6-8 weeks expected for this to get sorted. Depressing the other day as i was packing some bits into the loft and put some of my running stuff up there. On the upside i'm shedding weight barely being able to eat so should be a lot lighter when i get back to it.
