As in if you're doing 30 you're actually doing 26. This is pretty common on analogue dial cluster cars. It's usually a given it's around 3-4 secs out.
Every car I've had I've always gone up an inch or two on wheel size and fitted wider wheels/tyres with a lower profile. The speedo has always continued to read under, as I purposely have checked this, even when I've run taller profile really wide tyres and rims, like going from a 7.5J to a 9.5-10J, it still has red under.
It maybe different on newer cars with digital tachos/calibration, but wasn't the case for anything I've ever built/tested/driven, they have all red the same 3-4MPH real world difference, in my favour.
It varies depending on the car, but all 5 of my E36's for example have been 3-4 MPH out in my favour, and all 4 of my Honda's have been the same, as have any of my mates E28/34/36/38/39 BMW's.
I've driven a lot of older cars and none that are older have ever been 1:1 with a gps/satnav, always said it was going faster than it was.
I know on newer cars you can recalibrate the digital tacho if you change wheels/tyre size.
I don't think it's sus at all, and I'm reasonably sure that is 1 of the reasons the 1-3mph leeway existed, as there is a variance on old cars.
Do you mean in your favour? As in it says 30, and you're doing 26 or 28? Like my experience with older cars?According to GPS and the digital signage they have up from time to time in the villages around here on standard size wheels/tyres my vehicles (less than 10 years old) usually over read by ~2MPH on the speedometer, depending a bit on the speed. The AT set I have for my pickup push it out by about 3-4MPH and same, the other way, when the dealer put it on wrong size tyres![]()
Thought so, even changing wheels to bigger/wide ones with accompaning tyres has never made it a risk for me (ie under reading).Yeah if speedo says 30 and I go past one of the speed monitoring sign thingies in one of the villages it will say 28. I've got a GPS HUD thing, don't use it much as it poorly adjusts for light levels, and same for that.
Yep.Uther:
Our new car with a digital dash reads 32 mph at 30 GPS. I assume that's pretty standard as it gives a bit of leeway.
It'd only stitch you up if you ran smaller lighter wheels/tyres, due to less rotational mass, that's what I was trying to explain to @LuckyBenski
Check it with your phones GPS/dedicated satnav and compare it to the local speed trap readout and your dial cluster.EDIT: Actually I think it is the other way around. Depending a bit on how your vehicle calculates road speed.
Check it with your phones GPS and compare it to the local speed trap readout and your dial cluster.
I genuinely don't know anyone that's had this happen to them, most people I know drive 32 through 30mph cameras, due to this, as I remember before I could even drive I said "what are you doing" and they said it's fine there' a leeway.
I have accidentally done it once and yeah no flash, but I wouldn't ever do it on purpose cause I have terrible luck hahaha
Yeah tbh those things are what made me do my own testing, as I'd always been told by mates/people in the trade it was always in your favour, then found out myself this was true.Just Googled and there are calculators like https://tiresize.com/speedometer-calibration/ though they don't seem to quite match up with my experience. I think there is more to it than simply the circumference of the tyres. Depending on how your vehicle reads speed and maybe effect on the transmission, etc. I dunno.
Paint match is poorWingmirror done, what an absolute delight it was.....I'd liken it to inserting a cactus us ones bottom, I'm sure someone somewhere loves it, not me!!!
Paint match is poor
Hopefully a clean and polish will help the paint match, because it's kinda unfortunate that it's a slightly different shade.
Definitely a vast improvement though!
