Out for a morning round today, tee'd off just before 7, finished at 8:15, lovely
Haven't actually played my local for a while because of my elbow, I'm now 99% sure it was/is from carrying not golf and my local has various 'stages' of carry-only policy over winter, currently it's 'carry if you can' so I could've used a trolley but try not to.
So instead of carrying a full bag I took my pencil bag with 4 clubs in it, I was quite tempted to just take a 7-iron, as in no bag just a 7i, glove, tee's, couple of balls and walk around like that but thought I'd take at least a few others just in case I got too frustrated with my 7i. The others were a putter (which I actually used) my hybrid and a 60-degree, the latter two didn't get used though.
Score wise it wasn't great (54, should be mid-high 40's for me) but that's not terrible, especially as my reasoning for taking the 7i out is because I suck at hitting it these days
I think it's the point where my terrible swing starts 'not working' with an iron, my 8i is fine my 7i is junk. Even today I didn't hit one longer than 128 yards which is bad even for me, on the plus side I feel like I got more confident with it over the round and especially with shorter 'bump and run' type shots around the green which is a skill I didn't think I had, preferring to use my 54-degree almost exclusively.
Also putting was solid <2 putts per hole is always nice.
The past two days I've also been out on the range, I did pick up a Garmin Approach R10 and it works quite well, I was a bit wary because the balls at my local range are not the best quality and also very variable but it seems ok, maybe not getting the best spin numbers especially on higher spinning clubs like the wedges but overall it seems to be there or thereabouts with everything so that's nice. Hoping that can help me with my awful swing
Yes we've had a few good bits from it. It took a little while as I think you have to be a bit consistent and build up a bit of trust.
My company is around Property Surveying, Valuations, EPC's and Retrofit etc. I've also met good people who have been really helpful with starting to grow the business too on just simple day to day bits and bobs. Yes it's paid for through the business which helps obviously.
Do you by any chance have access to a 'golden ticket'... I might be interested
What level of membership do you have? Can you change easily as well, thinking Standard would probably be enough but not looked too closely at the options/benefits.
