- 28 May 2021
- Uk
Does any one know when this will be released in the U.K. at all
Be sure that you can downscale to 32 first, I tried with the new Alienware and found my 42 superior overall (but it is an oled too).Yet again looks like the UK is shafted.. this would be ideal, though I do kind of like my C2 42", and the newer versions dont have MLA right?
This is a great point, I had a Acer 32K 4K screen, and that did feel very much inferior, but it was a poor IPS to start with. I'll have to wait for reviews I guess, I am perfectly content with the c2 for now.Be sure that you can downscale to 32 first, I tried with the new Alienware and found my 42 superior overall (but it is an oled too).
I should imagine so, esp as the Alienware has it (and coming to the Asus iirc).I do wonder if this 32" panel comes with all the normal LG features like dolby vision etc.
Dolby Vision support is scaler dependent and limited in its availability right now. LG don’t list it as supported on this model unfortunately so I don’t think it will have itI should imagine so, esp as the Alienware has it (and coming to the Asus iirc).
Ahhh ok, thanks for clarifying B.A.Dolby Vision support is scaler dependent and limited in its availability right now. LG don’t list it as supported on this model unfortunately so I don’t think it will have it
Take one opinion with a grain of salt
This might be the one for me, prefer matte coating.
but if you prefer it like optimum it's an easy choice for you. He also doesn't particularly care for a very bright screen, based on several other reviews of his I've seen.
That’s a curved panel though, which I guess will be personal preference. The MSI version with that panel is a lot more expensive.Hard to justify this and the other 240HZ OLEDs when the Alienware AW3423DW is only ~930 after corp discount. Dunno why these are so overpriced in the UK.
If this was closer to 1k I think it's the OLED I'd get, but not at this price.
