- 14 Jul 2005
- Birmingham
Update.
I had to buy a different adapter to work with my car on the Android version of bimmerlink. I got a Vlinker MC+, I will return the Veepeak one.
This allowed me to register new battery, which as suspected one had never been registered before.
On the aux belt, I went into a local BMW indy which has a very good reputation and which I used before to do my rocker cover gaskets. They had a look at the belt and the area around the crank pulley and think that no further damage has been done. Hopefully they are correct. The only way to be 100% sure would be to drop the oil pan.
I will keep an eye on things closely, but the belt I fitted appears to be running just fine, so I think it was fitting error and the belt I had replaced just five months ago probably got chewed up in the first few hours of it being done. I reckon they didn't slot it into one of the pulleys properly, so it was misaligned and rubbed on something, causing it to rip apart. Lucky escape.
Lesson for everyone, if you get a garage to do any work, always check it after. Cannot trust hardly anyone these days.
All that is left to do now is fit the new oil cap, but its raining so that's a job for tomorrow. Hopefully that seals better and I can then see if there is any more oil seepage from anywhere else.
