If you're playing at 1080p right now, then even a 4070 is technically overkill (since it is meant for 1440p), but my suggestion would be the 7900 GRE, since it is a fair bit faster than the non-Super 4070 and if you upgrade early, it can still do the job:After a few of your comments, I am thinking around whether I should go with a different GPU. Maybe just a 4070 instead of the 7900XTX. It would probably be sufficient but then again...it's always a few hundred more and it could be spectacular instead![]()
4K Gaming Doesn't Have to be Expensive - AMD Radeon RX 7900 GRE PC Build
Building an Affordable Radeon RX 7900 GRE 4K Gaming PC This video is sponsored by GIGABYTE. You can find all the parts I used below *System Specs / Parts...
